23526 Discussions
Needing help to update my graphics driver
RAran2
I'm trying to update my graphics driver but the update utility don't work. I use Firefox 27 and the latest version of Java is installed.
I also tried to update it manually but I can't figure out from wich generation is my graphics adapter.
The following is all the info about my desktop's system I can provide:
SYSTEM
Processor : Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz (4 CPUs)
Memory : 1910 MB
System Type : Windows XP Professional 2002 version Service Pack 3
DISPLAY
Name : Intel(R) HD Graphics
Manufacturer : Intel Corperation
Chip Type : Intel(R) HD Graphics (Core i5)
DAC Type : Internal
Approx. Total Memory : 1024.0 MB
Version : 6.14.0010.5237
Also, I fear for incompatibility or any other issues. This my first time updating drivers.
Thanks!
Kevin_M_Intel
Hi rogiaran,
I am sorry to hear you are having problems to install the driver but let me help you.
You can download the driver for your controller at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20783 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20783
If you are having problems during the installation of the driver you can try the manual driver installation. Here you have the steps:
http://www.intel.com/support/graphics/sb/CS-030331.htm http://www.intel.com/support/graphics/sb/CS-030331.htm
