23767 Discussions
No HDMI output
DHaze1
I have a HP Pavilion X2 10-p103tu all-in-one tablet which does not display a HDMI output. I have run the HP PC Hardware Diagnostics and during this test, the 'Thunderbolt; test failed. I have the latest, according to the Intel site, drivers, but still no HDMI output. Has anyone got any ideas? The tablet has just run out of warranty, typical !
n_scott_pearson
I suggest that you try installing the latest available Intel HD Graphics driver that you can find (and is for your PC) on the HP website. Often, problems like this are caused by Windows Update installing later versions of the driver that have issues with your hardware. If the output still has issues, you will need to contact HP for assistance.
Hello, Hazellnut.
I agree with the instructions provided by N.Scott Pearson, were you able to perform those steps? In the case that the steps did not fix your issue please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Antony S.
DHaze1
Thanks for the advice. Have attached output file as requested.
Hello, Hazellnut.
Thank you very much for your reply and the information provided.
Please update the Graphics drivers of your system by using the Intel® generic drivers. Click https://downloadmirror.intel.com/27267/a08/win64_154037.4835.zip here in order to download the latest version and, in order to complete the installation, follow this guide: https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html
Additionally, try to get in touch with https://support.hp.com/us-en/contact-hp HP* Support in order to get the latest BIOS version for your system.
Please share with us the results.
Antony S.
DHaze1
Thanks Antony for the advice.
I have updated the BIOS, with the latest, and also did the Audio and Chipset. Tried the link from Intel as you suggested and got the following error:
Error Message: Computer Manufacturer Graphics Driver Detected
Article ID: 000005469
Why did I get this error?
Your computer manufacturer customizes drivers that run Intel® components on your machine.
so unable to load Intel graphics. Have tried the HDMI output again, with still the same result. Will pick up a new micro HDMI tomorrow and see what happens.
Dave
DHaze1
After all the problems trying to resolve this issue, I was able to replace the 'new' Micro HDMI cable with an adaptor. The computer instantly recognised the adaptor and my screen display was displayed on the TV.
I will now go and return my 'new' cable to the reputable company from where it was purchased.
Many thanks for all your assistance with my HDMI issues. I'm glad it's resolved.
Dave
n_scott_pearson
In my experience, the problem is caused by the cables 75% of the time. HDMI-to-VGA and DP-to-VGA adapters are regularly found to be bad as well.
You get what you pay for,
DHaze1
The cable would have been the first choice, but I did not have another Micro HDMI device, to check the cable. I had to wait.
I do agree with your post though, most faults can be traced to cables.
Many thanks
Dave
DHaze1
Check cables, as all is good once I picked up another cable.
