22974 Discussions
No audio through HDMI with HD 4400
VForo
Hi everybody. I have a sony vaio Pro 13 with Intel(R) HD Graphics 4400 and windows 8.1. When connecting the laptop via HDMI to the TV i can see the video but not sounds. In the Audio settings i can clearly see an HDMI device but it's always NOT PLUGGED IN.
Anyone can help me?
I can all the driver audio and video update, and the only issue that i can notice is that is impossible for me to install the HD graphics 4400 driver version 15.x because my computer is "not suitable" . I have the version 10.18.10.3304
Kevin_M_Intel
Hi Vittorio,
Since you have an OEM system, I can provide the generic graphics driver for your controller. You can download the latest graphics driver at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23323&lang=eng&OSVersion=Windows%208.1%2C%2064-bit*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
The above driver is a generic driver so in the case that the driver is not working, I recommend you contacting the computer manufacturer to get the Audio driver and the Graphics driver for your system.
DCost5
Same problem, apparently these drivers are not generic enough because it doesn't allow me to install them.
Also, the visible hdmi playback device turned off used to happen in the past months, with latest drivers i don't even see it anymore.
The only way to have hdmi audio is removing everything until version 9.x.x.x (and having artifacts in browsers).
Kevin_M_Intel
Hi Evil,
My best recommendation for you is to update the BIOS in your computer and install the latest drivers including the Digital Audio driver from the computer manufacturer.
DCost5
done and done, but same problem
btw i did not notice that the manual procedure allows to install the latest you mentioned, but didn't change a thing.
however, i might have found an acceptable solution.
i noticed that the problem was the intel audio device, which is updated with the graphics drivers, so i installed latest (the one you suggested), then i uninstalled the intel audio device and updated its drivers only by picking into my manufacturer's drivers (which were for win8, with video still with visual artifacts).
this seems to work under all aspects so far.
Kevin_M_Intel
I am happy to hear that.
DCost5
unfortunately after each reboot hdmi disappears and i need to do the procedure above again 😕
DLowe1
I also have a sony vaio pro 13 touch, No audioi through hdmi. I cant even see the intel audio under device manager. My only audio devices are realtek and a bose soundlink which is my bluetooth speaker. somebody help. Ive updated everything
DCost5
try what i mentioned in the recent posts.
it is not perfect but it work(ish).
for me right now hdmi works only in one condition: tv is turned on and plugged in, reboot pc, login, and the audio should be on the tv (even if muted, sometimes, just unmute it).
whatever you do (turn off, sleep, reboot), it won't work again until you do the above.
btw: this is not annoying at all for a product over 1000€...way to go sony OR intel...
Kevin_M_Intel
Have you checked for recent bios updates for your computer?
LAyud
Hi, I have an Intel i3 4130T on Windows 7 32bit with the lastest Intel drivers- That´s works fine and I have hdmi audio, BUT when I power off the TV and switch on it again I lost the audio device (doesn´t work any more), So I must restart the system with the tv power on if i want to have audio again...
I didn´t have this problem with an ATI video card that i had before.
Any help or solution please.
LAyud
Hello I´m still restart the system any time I want to listen audio.
That´s the only way Works intel´s apus? Any fix or patch?
thanks
Kevin_M_Intel
Hi Lucas1409,
Can you post your dxdiag report here please?
LAyud
Hi Kevin YES
REPORT:
System Information
Time of this report: 12/28/2013, 11:37:15
Machine name: SALON-PC
Operating System: Windows 7 Home Premium 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.130828-1532)
Language: Spanish (Regional Setting: Spanish)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: B85M-D3H
BIOS: BIOS Date: 10/24/13 20:58:52 Ver: 04.06.05
Processor: Intel(R) Core(TM) i3-4130T CPU @ 2.90GHz (4 CPUs), ~2.9GHz
Memory: 2048MB RAM
Available OS Memory: 1792MB RAM
Page File: 1077MB used, 2507MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4400
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_041E&SUBSYS_D0001458&REV_06
Display Memory: 832 MB
Dedicated Memory: 192 MB
Shared Memory: 640 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Monitor PnP genérico
Monitor Model: Philips FTV
Monitor Id: PHL0000
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: igdumdim32.dll,igd10iumd32.dll,igd10iumd32.dll
Driver File Version: 10.18.0010.3345 (English)
Driver Version: 10.18.10.3345
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 10/28/2013 14:01:52, 11434496 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-475E-11CF-F97A-0AF0BBC2C735}
Vendor ID: 0x8086
Device ID: 0x041E
SubSys ID: 0xD0001458
Revision ID: 0x0006
Driver Strong Name: oem13.inf:IntelGfx.NTx86.6.1:iHSWD_w7:10.18.10.3345:pci\ven_8086&dev_041e
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
XXXWHITE...
LAyud
Hi Kevin, Yes
thanks
System Information
Memory: 2048MB RAM
DxDiag Notes
Display Devices
DAC type: Internal
Monitor Id: PHL0000
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: n/a
Vendor ID: 0x8086
Device ID: 0x041E
Revision ID: 0x0006
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IM...
LAyud
Hi kevin, Yes
thanks
LAyud
System Information
Memory: 2048MB RAM
DxDiag Notes
Display Devices
DAC type: Internal
Monitor Id: PHL0000
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: n/a
Vendor ID: 0x8086
Device ID: 0x041E
Revision ID: 0x0006
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Kevin_M_Intel
Hi guys,
Thanks for the information. Based on the report all drivers are up to date as it should.
At this point we are getting reports from other customers about this issue and it is being investigated by our engineers to have a solution ASAP.
I will keep you posted about this.
Kevin_M_Intel
Hi All,
The Engineering team is requesting more information than what you have provided but I will need this from people who are having problems:
  1. Copy and paste the complete dxdiag report. Before doing this, make sure all drivers are up to date.
  2. Copy and paste the Graphics report by accessing the Graphics Control Panel> Information Center> Save.
I will appreciate if you can provide this information and I am sorry to bother you again.
DLowe1
Report Date: 1/2/2014
Report Time[hh:mm:ss]: 18:21:27
Driver Version: 10.18.10.3304
Operating System: Microsoft Windows 8.1(6.3.9600)
Default Language: English (United States)
Installed DirectX* Version: 11.2
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.2
Physical Memory: 4002 MB
Processor: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
Processor Speed: 1600 MHz
Vendor ID: 8086
Device ID: 0A16
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4400
GOP Version: 5.0.1025
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Connector Type: Embedded DisplayPort
Serial Number: MEI96A2
Gamma: 2.2
DDC2 Protocol: Supported
Device Type: Built-in Display
Maximum Image Size:
Horizontal: 11.42 inches
Vertical: 06.69 inches
Monitor Supported Modes:
1920 by 1080 (40 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 34 A9 A2 96 00 00 00 00
FF 17 01 04 A5 1D 11 78 02 95 21 A6 53 53 98 25
0B 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 02 3A 80 58 71 38 0D 40 2C 06
92 00 58 C1 10 00 00 1E 02 3A 80 58 71 38 30 42
2C 06 92 00 58 C1 10 00 00 1E 00 00 00 FD 00 26
3E 40 43 0F 01 0A 20 20 20 20 20 20 00 00 00 FC
00 56 56 58 31 33 46 30 30 39 47 30 30 0A 00 0A
* Other names and brands are the property of their respective owners. *
System Information
Time of this report: 1/2/2014, 18:18:33
Machine name: AGENT_VAIO
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_gdr.131030-1505)
Language: English (Regional Setting: English)
System Manufacturer: Sony Corporation
System Model: SVP13213CXB
BIOS: R1043V7
Processor: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz (4 CPUs), ~1.6GHz
Memory: 4096MB RAM
Available OS Memory: 4002MB RAM
Page File: 4787MB used, 879MB available
Windows Dir: C:\WINDOWS
System DPI Setting: 144 DPI (150 percent)
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Sound Tab 1: No problems found.
Display Devices
Card name: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0A16&SUBSYS_90B6104D&REV_09
Display Memory: 1792 MB
Dedicated Memory: 0 MB
Shared Memory: 1792 MB
Monitor Model: VVX13F009G00
Monitor Id: MEI96A2
Native Mode: 1920 x 1080(p) (60.011Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3304 (English)
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Date/Size: 9/16/2013 08:32:34, 12081664 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4956-11CF-157F-BCB0B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0A16
SubSys ID: 0x90B6104D
Revision ID: 0x0009
Driver Strong Name: oem68.inf:5f63e5341cc65b69:iHSWM_w81:10.18.10.3304:pci\ven_8086&dev_0a16&subsys_90b6104d
Rank Of Driver: 00DA0001
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch ...
DLowe1
System Information
BIOS: R1043V7
Memory: 4096MB RAM
DxDiag Notes
Display Devices
DAC type: Internal
Monitor Id: MEI96A2
DDI Version: 11.1
Miracast: Supported
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x8086
Device ID: 0x0A16
Revision ID: 0x0009
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_Stretch...
