23525 Discussions
No audio through HDMI with HD 4400
VForo
Hi everybody. I have a sony vaio Pro 13 with Intel(R) HD Graphics 4400 and windows 8.1. When connecting the laptop via HDMI to the TV i can see the video but not sounds. In the Audio settings i can clearly see an HDMI device but it's always NOT PLUGGED IN.
Anyone can help me?
I can all the driver audio and video update, and the only issue that i can notice is that is impossible for me to install the HD graphics 4400 driver version 15.x because my computer is "not suitable" . I have the version 10.18.10.3304
RKaup
I have the same issue here. I have an ASRock B85M-ITX motherboard, with an i3-4130T processor (therefore HD graphics 4400). When I connect to my TV through HDMI, the HDMI sound output is saying "not plugged in".
The BIOS is up to date (version 1.90), and I have tried the following graphics drivers:
ftp://europe.asrock.com/drivers/Intel/VGA/VGA(v15.31.11.64.3186).zip ftp://europe.asrock.com/drivers/Intel/VGA/VGA(v15.31.11.64.3186).zip (recommended by ASRock support team)
ftp://europe.asrock.com/drivers/Intel/VGA/VGA(v15.33.15.64.3431).zip ftp://europe.asrock.com/drivers/Intel/VGA/VGA(v15.33.15.64.3431).zip (same)
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3719&DwnldID=23639 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3719&DwnldID=23639
(latest from Intel download centre). Same issue all the time.
Outputs below.
Thank you!
Here is the Intel Control Panel output:
Report Date: Wednesday, March 12, 2014
Report Time [hh:mm:ss]: 10:48:03 PM
Driver Version: 10.18.10.3431
Operating System: Windows* 8.1 Pro(6.3.9600)
Default Language: English (United Kingdom)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.2
Physical Memory: 15269 MB
Processor: Intel(R) Core(TM) i3-4130T CPU @ 2.90GHz
Processor Speed: 2899 MHz
Vendor ID: 8086
Device ID: 041E
Device Revision: 06
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4400
Video BIOS: 2166.0
Current Resolution: 1920 x 1080
* Devices connected to the Graphics Accelerator *
Active Displays: 1
Inactive Displays: 1
* Monitor *
Display Type: Analog
Serial Number: PKB0385
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: VGA
Device Type: Monitor
Maximum Image Size
Horizontal Size: 18.9 inches
Vertical Size: 10.63 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (75p Hz)
1024 x 768 (70p Hz)
1024 x 768 (60p Hz)
1152 x 870 (75p Hz)
1152 x 864 (75p Hz)
1280 x 1024 (75p Hz)
1280 x 960 (60p Hz)
1280 x 1024 (60p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1440 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 41 62 85 03 C7 B5 60 33
24 17 01 03 68 30 1B 78 CA 39 35 A2 59 52 A1 27
0C 50 54 BF EF 80 71 4F 81 40 81 80 81 C0 81 00
95 00 B3 00 D1 C0 02 3A 80 18 71 38 2D 40 58 2C
45 00 DD 0C 11 00 00 1E 00 00 00 FD 00 38 4C 1F
53 11 00 0A 20 20 20 20 20 20 00 00 00 FC 00 56
69 73 65 6F 32 32 33 44 58 0A 20 20 00 00 00 FF
00 44 32 52 45 45 30 30 35 38 35 31 30 0A 00 44
* Digital Television *
Display Type: Digital
Serial Number: JVC21f1
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 6.3 inches
Vertical Size: 3.54 inches
Supported Modes
640 x 480 (60p Hz)
720 x 576 (50p Hz)
720 x 480 (60p Hz)
720 x 576 (50i Hz)
720 x 480 (60i Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (24p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (60i Hz)
Other names and brands are the property of their respective owners.
Here is the dxdiag output:
System Information
Time of this report: 3/12/2014, 22:40:38
Machine name: ODRERIR
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_gdr.131030-1505)
Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 12/10/13 15:40:28 Ver: 04.06.05
Processor: Intel(R) Core(TM) i3-4130T CPU @ 2.90GHz (4 CPUs), ~2.9GHz
Memory: 16384MB RAM
Available OS Memory: 15270MB RAM
Page File: 1626MB used, 15947MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Inte...
