23833 Discussions
No driver installed with Matrix Storage Manager
I am trying to Migrate data from 1 hd to a RAID 0 Array. I am currently working on an XP pro 64 bit OS. I have had no problem in the past when doing the same thing with the same equipment but a 32 bit environment. when I run report through the storage manager, it says that there are no drivers found or Driver Version: File not found to be specific. In earlier versions, the storage manager and the the driver were downloaded seperately. with version 8.8, I try and download the driver and get the storage array manager software. Am I missisng something?
System Information
Kit Installed: 8.8.0.1009
Kit Install History: 8.8.0.1009, Uninstall
Shell Version: 8.8.0.1009
OS Name: Microsoft(R) Windows(R) XP Professional x64 Edition
OS Version: 5.2.3790 Service Pack 2 Build 3790
System Name: GHOST_390_64
System Manufacturer: Dell Inc.
System Model: 0DN075
Processor: Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz
BIOS Version/Date: Dell Inc. 2.6.0 , 05/19/2008
Language: ENU
Intel(R) Matrix Storage Manager
Intel Serial ATA Controller: Intel(R) ICH7R/DH SATA AHCI Controller
Number of Serial ATA ports: 4
Serial ATA Plug-In Version: 8.8.0.1009
Language Resource Version of the Serial ATA Plug-In: 8.8.0.1009
ISDI Library Version: 8.8.0.1009
Hard Drive 0
Status: Normal
Device Port: 0
Device Port Location: Internal
Current Serial ATA Transfer Mode: Generation 2
Model: ST3160812AS
Serial Number: 5LSBQG1F
Firmware: 3.ADJ
Native Command Queuing Support: Yes
Hard Drive 1
Status: Normal
Device Port: 1
Current Serial ATA Transfer Mode: Generation 1
Model: ST3160811AS
Serial Number: 6PT4RSTR
Firmware: 3.AAE
Unused Port 0
Device Port: 2
Unused Port 1
Device Port: 3
