23765 Discussions
Onboard-graphic - Problems displaying lines
i am using a "Siemens IPC 547D" with onboard-graphic "Intel HD Graphic". Here i installed already the newest driver for XP version 6.14.10.5415.
I am having problems with a program called "Agilent VEE". Here i can read numbers and display them in a graphic object.
Attached the two screenshot display the yellow line. Normally the yellow-line should not have any blank parts between.This example displays 401 points and connects them with lines so that at the end i looks like a curve.
In the example the user can click in the Start-button, then a textfile ir read that puts the content in the display-object. After each new read of the text-file the yellow line looks different and not all data is displayed.
==>When i uninstall the Intel-driver in windows and use the default-driver then i see the correct picture. <==
Are there any other drivers that i can install to have a correct display?
http://www.pic-upload.de/view-14876049/1.jpg.html Pic-Upload.de - 1.jpg
http://www10.pic-upload.de/28.06.12/lxqyimf65c69.jpg http://www10.pic-upload.de/28.06.12/lxqyimf65c69.jpg
Allan_J_Intel1
Hi there!
According to the computer specifications, the graphics is 2nd generation, the latest graphics driver is version 6.14.10.5415, and I do not have similar issues reported with that graphics driver version.
Try testing an earlier version
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21225&ProdId=3319&lang=eng&OSVersion=Windows%20XP%20%20Professional*&DownloadType=%0ADrivers%0A
Or check with Siemens to see if there are customized drivers for your computer model.
Allan
Hi allan_intel.
Earlier driver does not help.
The soution was to disable the graphic-acceleration in windows.
Can be found here (for XP)
Rightlick on desktop
+ Tab: "Settings" (Einstellungen)
+ Tab: "Advanced" (Erweitert)
+ Tab: "Troubleshooting" (Problembehandlung)
+ Slider Hardwarebeschleunigung: auf "Keine"
I think there are a lot of issues with this driver as there are also a lot of problems when using office as i saw in other threads here.
TM
