23769 Discussions
OpenGL Bugs
if i use constant vertex attribute (color) in combination with vertex attribute array (position) the constant vertex attribute is set only on the first vertex. the triangle strip of a red box fades to black from first vertex in the right top corner to the last vertex in the left bottom corner. same .exe on the nvidia chip on the same notebook gives expectet result (fully colored rectangle). both attributes as arrays work ok.
forgotten: intel i5-3317u with hd 4000, latest windows 7 (64 bit) driver and the 2 drivers before.
MSchm21
Valued Contributor I
Fred_D_Intel
Hi Chris Walrabe,
Thanks for the feedback you provided to us. I will forward this information to the appropriate support group.
