23780 Discussions
OpenGL problem with i5-7300hq
HTan12
I bought a new laptop with an intel i5-7300hq, there is a problem on the intel graphic when i launched a program that run based on openGL, when launching the program it shows the error code "can't find the name of intel icd opengl driver". After research from various forum it seems to be solved with intel latest driver (15.45) found in the page of i7-7700hq https://downloadcenter.intel.com/product/97185/Intel-Core-i7-7700HQ-Processor-6M-Cache-up-to-3-80-GHz- Downloads for Intel® Core™ i7-7700HQ Processor (6M Cache, up to 3.80 GHz) and not from the page of i5-7300hq https://downloadcenter.intel.com/search?keyword=7300hq https://downloadcenter.intel.com/search?keyword=7300hq. There is only beta driver of version 15.45 which doesn't even can be installed. Why is this happening with the i5-7300hq despite most of the other supported models included also used hd graphic 630 or similar version and only the i5-7300hq is excluded in the driver installation. updating it via device manager also didn't helped. Rolling back driver also didn't help too.
is there any other solution for "can't find the name of intel icd opengl driver" ?
Hi hamato,
I understand you are getting an error message when opening OpenGL applications. Let me help you on this matter.
I would like to know if you are still experiencing same problem after testing https://downloadcenter.intel.com/download/26669/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=98909 driver version 4627 and your computer manufacturer's drivers.
If the problem remains, please fill out the following form as complete as possible
/thread/77761 https://communities.intel.com/thread/77761
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box.
Allan.
Hi hamato,
I would like to know if you were able to fix this problem
Please check the link below for a newer graphics drivers version 4664
https://downloadcenter.intel.com/download/26772/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=98909 https://downloadcenter.intel.com/download/26772/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=98909
Let us know if this is working for your computer.
Allan.
HTan12
Hi Allan
The driver from the link you provided cant be installed, i'm getting the error message of "This computer does not meet the requirements for installing the software"
But luckily, I have installed the latest driver successfully by uninstalling the intel HD graphic driver using windows device manager and reinstall it by update microsoft basic adapter and choosing intel HD driver 15.45(extracted zip file) and it is works! However i'm still getting the error message "can't find the name of intel icd opengl driver" when launching a game called OSU! with compatibilityContext set to 1. Basically what this compatibilityContext in the game do is to translate OPENGL into DIRECTX if i'm not mistaken. There is also report from OSU! forum who have the same problem after installing newer intel HD graphic driver however not with the old driver that is about a year ago. Since my laptop is with kaby lake generation, it is quite new and there is no drivers older than a year.
And it would appreciated if Intel add driver support for i5-7300HQ to the graphic driver list to prevent installer pop-up "This computer does not meet the requirements for installing the software" message again.
Here is all the information
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Error message "can't find the name of intel icd opengl driver" when opening OSU!
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Lenovo Y520-15IKBN
<span style="f...
Hi hamato,
Thank you for reporting this matter. I am currently reviewing this issue. This thread will be updated as news become available.
Allan.
Hi hamato,
I am still reviewing this case and I need the following information:
Please confirm if you tried to download OSU! from the link below:
https://osu.ppy.sh/p/download https://osu.ppy.sh/p/download
Did you install the application directly on C: drive? Did you change installation location?
Thank you for your time.
Allan.
APera1
I changed installation Location to Desktop
HTan12
Hi Allan
i have tried to install it in C drive and E drive(Another hard disk) and both didn't work
ragards
Hello hamato,
Excellent information, thank you for taking the time and update this post.
Allan.
Hello hamato,
I just sent a private message. Please check your Inbox.
Allan J.
Hi hamato,
Thank you for the information.
Intel will keep tracking this issue at /thread/110921 https://communities.intel.com/thread/110921
Allan J.
