23586 Discussions
Optimus, HDMI, full-time 5.1 audio -- How?
MFili11
Win10-1803.
I have a 5.1 HDMI audio extractor connected to an Optimus system. The integrated GPU is Intel(R) HD Graphics 530.
Since the TV is 2.0 audio, that's all I'm getting. I want 5.1 audio and I want it 100% of the time, no matter what's plugged in, no matter whether nothing's plugged in, no matter whether whatever is plugged in is ON or OFF.
Any ideas how I can achieve that?
Mark.
AndrewG_Intel
Hello MFili11,
Thank you for posting on the Intel® communities and for the details provided.
In order for us to understand better the configuration you are trying to achieve, could you please confirm the following information?
1- Please elaborate more on how exactly you are connecting all the devices? How are the devices connected to one another? cables types, etc.
2- Brand and model of the 5.1 HDMI audio extractor, TV and "Optimus system". You may also provide some links as a reference.
3- Please provide more details on what you are trying to achieve. For instance, are you trying to output the audio signal from the system and play it on the sound device from the Audio extractor?
Andrew G.
A Contingent Worker at Intel
MFili11
Hi Andrew,
I'm conducting some tests that require HDMI audio to be on continuously instead of loading & unloading.
AndrewG_Intel
Hello MFili11,
Thank you for your response.
However, we would need to understand better how you are connecting the devices and more information like brand and models (links as a reference, etc.)
1- Please describe in detail how the devices are connected to one another and provide details about video outputs, cables, adapters (if any) in use.
Andrew G.
MFili11
Hi Andrew,
I appreciate that you want to solve a problem here. I have many problems including channels not driven (2.0 versus 5.1), Windows crashing when HDMI is unplugged, symptoms that change depending whether the HDMI is directly plugged in (thereby connected to the Intel 530) or plugged into the DisplayPort (thereby connected to the NVIDIA 980M). I'm conducting tests to narrow down the issue but those tests require the HDMI be loaded and continuously driven.
You ask for details, so of course I will provide them.
[ Acer Predator G9-792 gaming laptop ]---HDMI---[ noname (Chinese) 5.1 HDMI Audio Extractor ]---HDMI---[ Sharp LC-42LB261U TV ]
-OR-
[ Acer Predator G9-792 gaming laptop ]---DP---[ DP-to-HDMI ]---HDMI---[ noname (Chinese) 5.1 HDMI Audio Extractor ]---HDMI---[ Sharp LC-42LB261U TV ]
The 5.1 HDMI Audio Extractor is externally powered, and it connects to audio amplifiers via 6 RCA jacks.
MFili11
I have more information.
With HDMI connected, when I shut off power to the HDMI Audio Extractor, Windows throws an exception.
System Service Exception
HdAudio.sys
AndrewG_Intel
Hello MFili11,
Thank you for all the details provided.
Please allow us to take a look into this scenario, as soon as we have more details we will be posting back in this thread.
Andrew G.
MFili11
Andrew, I think you're going to want this:
Report Date: Saturday, November 23, 2019
Report Time [hh:mm:ss]: 16:53:21
Driver Version: 24.20.100.6286
Operating System: Windows* 10 Home (10.0.17134)
Physical Memory: 32649 MB
Vendor ID: 8086
Device ID: 191B
Device Revision: 06
Graphics Output Protocol (GOP) Version: 9.0.1037
Current Resolution: 3840 x 2160
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
Processor Speed: 2592 MHz
Processor Graphics in Use: Intel(R) HD Graphics 530
Shader Version: 5.1
OpenGL* Version: 4.5
OpenCL* Version: 2.1
Vulkan* Version: 1.1.82
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 14.96 inches
Vertical Size: 8.27 inches
Supported Modes
3840 x 2160 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 06 AF 9B 10 00 00 00 00
00 19 01 04 A5 26 15 78 02 24 25 A8 50 36 B6 26
0E 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 66 D0 00 A0 F0 70 3E 80 30 20
35 00 7E D6 10 00 00 18 00 00 00 0F 00 00 00 00
00 00 00 00 00 00 00 00 00 20 00 00 00 FE 00 41
55 4F 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
00 42 31 37 33 5A 41 4E 30 31 2E 30 20 0A 00 3B
* Other names and brands are the property of their respective owners.
MFili11
Here is the Event Viewer records of Windows crashes that I presume were caused by HdAudio.sys when power to the HDMI Audio Extractor was disconnected. A fresh dump can be created whenever you'd like; all I have to do is disconnect HDMI. Note that the latest crash, not summarized below, was today when I disconnected the power to the HDMI endpoint. On the blue screen, as Windows thought it was sending a report to Microsoft, the screen said "PAGE FAULT IN NONPAGED AREA" but it didn't cite a cause. I presume that that crash overwrote C:\WINDOWS\MEMORY.DMP, but like I wrote above, I can reproduce the HdAudio.sys crash on demand.
Level Date and Time     Source                                     Event ID Task Category
Error 19-11-08 19:05:33 Microsoft-Windows-WER-SystemErrorReporting 1001     None         The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff8010c35a7f3, 0xfffffa0e1dc7e7e0, 0x0000000000000000). A dump was saved in: C:\WINDOWS\Minidump\110819-9218-01.dmp. Report Id: 7a7bf9b5-5adf-48c8-90d6-8b295e694798.
Error 19-11-09 13:31:02 Microsoft-Windows-WER-SystemErrorReporting 1001     None         The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0x0000000000000000, 0xffff850a842667d0, 0x0000000000000000). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 226a661c-3a72-475c-af27-397dc5f3abde.
Error 19-11-10 23:41:50 Microsoft-Windows-WER-SystemErrorReporting 1001     None         The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff800877433c0, 0xffffb58d7c73e920, 0x0000000000000000). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: c96ca35b-cd3d-43c2-8ab6-8bb233524ade.
Error 19-11-20 04:45:22 Microsoft-Windows-WER-SystemErrorReporting 1001     None         The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff8010a6733c0, 0xfffff88d125d67d0, 0x0000000000000000). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: bb67fdb9-5dfc-4a25-9e19-aaa2d0f1ad54.
Error 19-11-20 21:20:51 Microsoft-Windows-WER-SystemErrorReporting 1001     None         The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff80177ff33c0, 0xffffa601db4be7d0, 0x0000000000000000). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 6646060e-3c0a-429e-ab49-5509c73311ea.
Error 19-11-21 03:51:12 Microsoft-Windows-WER-SystemErrorReporting 1001     None         The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff801f4c433c0, 0xffffc9865d3a97d0, 0x0000000000000000). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 8874e35e-2901-4d27-ac29-558d38d5b04c.
Error 19-11-22 02:45:41 Microsoft-Windows-WER-SystemErrorReporting 1001     None         The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff801c0b533c0, 0xffffce05be81e7d0, 0x0000000000000000). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 126168a5-7559-4d6d-bd8e-bacc25c81d9d.
AndrewG_Intel
Hello MFili11,
Thank you for all the details provided and for your patience in this matter.
After investigating this situation, we would like to inform you that the driver will read the EDID (Extended Display Identification Data) from the end-point device and if it is 5.1 capable it will allow Windows configuration to be set as 5.1.
We tested this with the latest driver 26.20.100.7463 and connecting an Intel® NUC to an Onkyo 5.1 Receiver (HT-R395)*. Please find a screenshot attached.
At this point, we kindly recommend you to address this question to the manufacturer of the HDMI audio extractor device and contact their support team for more accurate assistance.
Andrew G.
