23782 Discussions
Override Application Settings Unchecks?
SGree10
So, I'm trying to check the "Override Application Settings" box on my control panel and it unchecks itself, no solutions found online, rolling back drivers wont work
Laptop: Lenovo Z50-70 i7 4510u intel graphics 4400 geforce 840M 4GB
Stefan3D
On your Optimus rig you can control applications from the NVIDIA control panel.
Check out: http://nvidia.custhelp.com/app/answers/detail/a_id/2615/~/how-do-i-customize-optimus-profiles-and-settings%3F How do I customize Optimus profiles and settings? | NVIDIA
Don't forget to hit the "Apply" button after changing a setting.
Hello SegevG,
I understand that the "Override Application Settings" option uncheck itself on the Control Panel.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
If possible please provide a screenshot of the exact setting you are trying to enable.
What is the issue you are having in the computer that is making you enable that setting?
Fred D.
Hello SegevG,
I was wondering if you still need assistance regarding the "Override Application Settings" option. In case you still need assistance just let me know.
Fred D.
