23542 Discussions
Override application can not be cheke
ManiGs
Hello.
Mani is here im aplologizing for submiting such a problame but i need a solution for my issue
I have intel graphic family card on my laptop and a nivida 840M extended card
i have instaled a new windows 10 but i founded that my intel family graphic card has changed to microsoft baisc so i ebdeted my graphic card from my windows update and i found that i can't check te override application in intel control panel wich do not allow me to use my maxium hertez in games so i play 60hz i need to check it so plesase help my out
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
