23734 Discussions
PC freezes while playing
Hello everyone.
I bought a new system a few days ago and while playing games, my whole computer freezes and I need to force shutdown with pressing the power button for 5 seconds.. Sometimes i can run a game for 2 hours, sometims it crashes after 5 minutes. I tested my hardware again and I came to the conlusion, that the Intel HD 4000 causes the problems (there is no other graphics card installed at the moment). I read some other topics on this board but none of the solutions worked for me.
Here is my System:
Windows 7 64bit
ARock Z77 Pro 3
Intel i5 3570k
1TB WD Green HDD
16GB Corsair Vengeance DDR3-1600 RAM
LG optical drive
Corsair power supply with 500W
Games I tested that froze after sometime: Skyrim, Left 4 Dead 2, no other games were tested.
I tested around and those are my results so far:
-running games in windowed mode also freezes my computer
-updating all my drivers, including my bios didn't help, even with an old 8.xx graphic driver my game freezes
-i tested my ram, game freezes with a single stick of ram installed, doesn't matter wich one
-the system doesn't freeze during benchmarks with full cpu usage
-the temperature does not effect the result, games freeze under 35°C
-allocating more ram to the gpu over bios does not effect the result either
-software problems are probably not occuring, because the OS was installed a few days ago
I used a user defined screen resolution because my monitor is a bit bugged, but i ran the game in normal full hd resolution 1920x1080. Could this cause freezes? If this is not the problem i really have no more ideas why my computer freezes. If you need more information, please ask.
Thanks for reading and I apologize for my english.
So I recently tested Skyrim and driver with the native 1920x1080 resolution and with the lowest 16:9 and nothing worked. A friend said, I should try another graphic card and i digged up my old Nvidia 8600 GT and I am running Skyrim for about 2 hours now without any crash. So there is a problem with the Graphics 4000 driver or the graphic chip itself. What do I need to do?
NICHOLAS_F_Intel
Hi tomok,
Did you buy a complete system, or did you build one yourself?
-Nic
I bought the hardware and a friend of a local computer-store built it for me. So a problem with the Hardware is unlikely, but i cant exclude it for sure.
NICHOLAS_F_Intel
In the last thread I was working with you in, you said you had tried to install your Asus* driver, but could not properly connect to the page in order to download it. Can you try that now and tell me if it works? Here's the link again; http://www.asrock.com/mb/Intel/Z77%20Pro3/?cat=Download&os=Win764 http://www.asrock.com/mb/Intel/Z77%20Pro3/?cat=Download&os=Win764
-Nic
The old graphics driver didn't fix the problem. Skyrim still freezes. I'm gonna install the latest driver again.
PS: I tested League of Legends, it froze too.
