23851 Discussions
PCI Memory Controller driver not found
driversaregone
My pci memory controller driver and SM bus controller driver is not found. I went to PCI lookup and found that the drivers are as the picture seen below but I can not find it anywhere. Can someone help me find the PCI memory controller please!
if you cant see it then refer to the file below.
That is the largest I can make that. Here are the drivers. If anyone can help me fix the other one too, that will be greatly appreciated.
driversaregone
Ok so I extracted right, I go to device manager and the errors are gone now? I can't find the pci stuff anywhere. The only thing I did was install intel chipset software installer. was that a bad move?
driversaregone
driversaregone
but wait, do I just download the latest one?
Stefan3D
Yes, sort by date to catch the latest.
Otherwise Windows update will sooner or later suggest to update a driver from 1968 🙄
driversaregone
Got it, thanks! And one more thing, after I click download a new web comes up with a link, what do I do there?
Stefan3D
Click the CAB file and choose download
unpack it the same way like a ZIP file to a new folder
in device manager select update driver for the messed up device
select have disk
navigate to the download folder and select the INF file
driversaregone
I keep clicking it but it wont download anything
driversaregone
Ok I got it, now Im gonna need a little more help as I dont know how to unpack it.
Stefan3D
A popular unpacker is 7zip
After installation you can right-click a CAB file and select extract to "xxx"
driversaregone
Stefan3D
If the yellow triangles are gone everything is fine.
The devices have different names now, similar to screenshot below
stefan133-20210405-173945
driversaregone
Nope. It looks like this.
like that?
Stefan3D
Perfect. No yellow triangles anymore.
Device A121 has the official Intel name now.
driversaregone
ok, thank you so much for your help!
AlHill
You need to install the MEI (management engine).
If that does not work, So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Childhood_is_over-3
I have that same issues too idk how to fix it i'm trying to find intel chipset driver to download it
n_scott_pearson
@Childhood_is_over-3, over 3 what? My kids are well over 3 decades old and they still act like children ;^)
Ok, bad-attempt-at-humor over with, to answer the question for you, we need to know what chipset your motherboard has.
Vulkany
I'm having this issue with the PCI Memory Controller
I've installed the Intel® Driver & Support Assistant and run it but didn't fix the issue.
I've also run the System Support Utility but when I try to submit the report I get
Any help would be greatly appreciated.
AlHill
@Vulkany You need to start a new thread for your issue and provide full information, rather than hijacking an old thread.
