23848 Discussions
Please improve VAAPI support for Linux
Hello community and Intel developers,
I have a HTPC running on a Core i3-330M with built-in IGP which I want to use as a media PC. Under Windows everything works fine - HDTV and HD playback is no problem.
But now I want to setup a HTPC with Linux (XBMC PVR) and read that there is the so called VAAPI support. But my experiences in the last days weren't that good.
While HD videos are played without any problems, there are some issues with HDTV. The driver often fails to decode TV channels and shows green picture and even HD deinterlacing is sometimes very buggy.
So I wanted to ask the developers if there are any plans to improve VAAPI support by Intel since nVidia is currently leading the situation with VDPAU.
Thanks in advance!
Sincereley,
FDF
Bear in mind that there is limited support for Linux on these graphics controllers, besides there are no drivers for it, if Windows* is working properly is due the drivers, therefore I recommend you keep using this OS
Any further reference about this issue I recommend you visiting the followin link:
https://www.linux.com/community https://www.linux.com/community
Dago M.
