23850 Discussions
Possible Direct3D 11 API implementation bug in HD 4000 driver
ABich1
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%):X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
i5-3570K
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Hybrid, but does not matter
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)<p style="margin-bo...
Hello alexanderi_gpu,
Thank you for joining the Graphics Community. I am sorry to hear you are having issues with this matter.
I would like to gather more information regarding this behavior;
  • Provide the model of your graphics card.
  • Provide the model of your computer model.
  • The app you developed is the only one that shows this behavior, correct?
Thank you.
Amy C.
ABich1
Intel HD Graphics 4000
Custom built PC using ASUS P8H77-I mainboard with Intel Core i5-3570K proccessor (family 6 model 58 stepping 9)
It is the only one, that I have for now, and it passes all the validation checks, imposed by Microsoft Direct3D 11 API, and works fine on any other Direct3D 11 compatible hardware, including Intel HD Graphics 530.
It would be great to know if the strange behavior of the app is reproduced in your labs. If it helps, I can redirect the issue to the driver development team.
/thread/118987 alexanderi_gpu, thank you.
By graphics card I mean the physical card not the integrated graphics controller. Do you know the model? Is it an AMD graphics card?
Amy C.
ABich1
AMD Vega Frontier Edition
Thank you for the information.
Does this behavior happen while using graphics driver from ASUS?
If you remove the graphics card, does the behavior happen?
Amy C.
ABich1
I will check this out a little later. But the very same problem occures in HD Graphics 4000 ( driver ver. 10.18.10.4276 ) on a different machine:
Custom built PC running Microsoft Windows 7 SP1 Ultimate edition with Intel Core i7-3770K processor and 2 descreet graphics cards:
AMD Radeon R7 200 Series
NVIDIA GeForce GT 630
That's why I think it is an Intel driver bug.
ABich1
The very same issue is in integrated Intel HD Graphics driver on Intel Atom Z3745 processor running on Windows 10 Professional on tablet FC-5000 manufactured by Topcon
It seems like it is reproduced on any Intel integrated graphics of 7th generation with Windows OS.
What was the model of the 7th system you tested?
Amy C.
ABich1
It is not a system, but the 7th generation of Intel graphics systems.
https://en.wikipedia.org/wiki/List_of_Intel_graphics_processing_units# Seventh_generation List of Intel graphics processing units - Wikipedia
It includes Intel HD Graphics 4000, Intel HD Graphics 2500 and Intel HD Graphics
So far I've tested:
Intel Atom Z3745, with Intel HD Graphics
Intel Core i5-3570K, with Intel HD Graphics 4000
Intel Core i7-3770K , with Intel HD Graphics 4000
All processors have Ivy Bridge architecture.
Works fine on Intel Core i5-6600 with Intel HD Graphics 530
I've added short videos when error is present and when everything works fine, see attachements in the first post.
/thread/118987 alexanderi_gpu, thank you for that information. I will double check this matter and update the thread as soon as possible.
In the meantime, I would like to ask the community the following: do we have any other instance of this bug manifesting itself on a publicly available application?
Amy C.
ABich1
If the driver development team is concerned by this issue, i'm ready to provide a very detailed issue description (beyond what's written in description.txt) or a source code of the demo app.
RonaldM_Intel
Hello Alexander,
Can you please provide us with a detailed issue description and specifics on how to reproduce it? (like you mentioned, a source code of the demo app).
The reason I'm asking is because 3rd generation graphics are quite old now, and so far this appears to be an obscure bug (i.e. not affecting too many users or even popular applications), thus I might need to provide compelling justification to our development team so that they pick this one from the queue.
I truly appreciate you taking the time to report this to us.
Ronald M.
ABich1
Hi, Sorry, I was busy lately. Concerning the source code, I have a project with a demo app, which can reproduce the bug. It can be assembled via CMake and built by MS Visual studio and does not require any dependencies.
Besides the issue text description, I was wondering, in what form You'd like to have a source code. I can send a whole project with a demo app, or I can try to prepare a small demo, which reproduces the bug, but it will take time.
Another annoying bug I found, is present in OpenCL driver implementation, which causes HD4000 driver to stop responding. It also is present on Ivy Bridge Integrated Graphics only. Should I create a separate thread or I can attach it here?
For now You can try to run a demo app in demo1.zip attachment on any Ivy Bridge desktop running MS Windows 7+ to see if the animation is working or not on your side. If the app is running and animation does not happen, - you are dealing with a driver error.
RonaldM_Intel
Hi again Alexander,
Thanks for the details. I'll move this internally to determine if we're moving on with further debugging. I'll like to point out that there is a chance that this won't be picked by our devs if the bug is obscure and cannot be replicated on popular applications.
I'll reply here as soon as I have further details.
Ronald M.
ABich1
Hi, I've decided it's more beneficial to just blacklist certain hardware with drivers issues and move on, than to spend time on fixing it. It's really getting too old. Since issue is not the case on more recent hardware, You can close the thread and the issue.
