23822 Discussions
Posts being marked as spam
Not applicable
Hey. I tried to make the same post two times regarding my issue. Both were marked as spam. Please help!
AlHill
As far as I can tell, they are not being marked as spam manually.  So, it is probably some link or keyword you are using that the auto spam checker is catching.
Make sure the post is clean, no questionable links, etc. and try again.
Not applicable
I tried reposting removing the links but no success, and the links are actually needed for the post I'm making. I guess I need a moderator to manually uncheck it as spam. 😕
AlHill
A moderator or forum manager will be by to check.
Not applicable
