23525 Discussions
Power Tab is Missing in IGCC for Panel Self Refresh
memolio
Core i5 12600K
Motherboard ASUS PRIME Z690-P WIFI D4
Ram DDR4 3600
I had a GTX6660 Ti that Stop Working last week
After Using Intel Graphic GPU My screen Start Shaking and stuttering , I Chenged RF to 60HZ interlaced screen stop shaking but now text is seems very bad with shaking
Changing to 60Hz P or lower RF or  changing resolution make screen Shaking very bad
searched internet for solution ,they said to chang setting in Intel Graphic Commond Center in System - Power tab But mine Dosent Have Power Tab.
Unistalled Driver From Device Manager and Installing Driver Again Dosent Help
Unistalling IGCC and reinstallin it Dosent Help  Even repairing or Reseting  it from Win Setting.
Installing Drivers From My motherboard webSite Dosent Help
Installed A new Windows 10 and the problem continue
Changing HDMI cable Dosent Help
Changing Monitor Dosent Help and also they didnt have interlaced setting So only have bad screen Shaking
Reducing Resolution Dosent help and screen Start Shaking and just 1080 60HZ intelaced works
with text shaking and texts are not clear like before
Tried To Install Intel® Graphics Control Panel but Windows Store Dosent let me to intall
installed IGCC beta but dosent Help.
I unistalled itel GPU Driver and Set to Microsoft Basic and Disabled Updating Driver Update Automatic then Restart , Screen Was Good with Clear text without Shaking but Now All of the features has gone .
please Help ME.
Steven_Intel
Hello memolio,
We are currently working on your issue. As soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Hello memolio,
Please perform the following steps:
As well, please be aware that the Power tab in the Intel® Graphics Command Center does not show in desktop systems, as the information there refers to power settings for laptops and mobile devices.
Steven G.
memolio
Thank Steven G. (Steven_Intel) For Help
unfotunately My Monitor Only HAve HDMI , D-Sub, DVI-D
I Tried HDMI TO D-Sub Cable But Screen Still Shake
Bios Screen is great without any Problem.
I Updated My win 11 Fully and tried a Fully Updated Win 10 but nothing changed.
also I Have Tried Fully unistalling the Driver and Updating It To the Last One .
but now I see there is another Driver has Came So I will try this One tomorrow.
Is there Any Setting I can do from Registry To Disable Panel Self Refresh or enableing it to test if its work?
memolio
I Uninstalled Driver via Device manager ,turned off internet , restart and installed driver v31.0.101.3222.x64 that I have downloaded from intel website and just when when driver was installing my text turned uncleaer wih abit shaking. and refresh rate changed to 60Hz (interlaced)
changing to 60p or lower setting like 59.93Hz or 59.94Hz or 50Hz make screen shake with color problems.
I Test a wireless android  Television with an app named spacedesk And is Was OK without Any Problem.
Steven_Intel
Thank you for your response.
I would like to work on this issue. In order to do so, please provide the following information:
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Steven_Intel
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
