23791 Discussions
Problem finding correct Intel HD Graphics Driver for i3 330M
NMcJo
Hi, I need Intel HD Graphics Driver for Windows 7 64 bit for i3 330M, for my laptop.
Can't find it at download center, keeps prompting me to download drivers for i3 3000
series, i need 300 series though. The 3000 series drivers cannot run at my system which
, by the way, is fully updated. I tried to install the file downloaded from the download
center but it doesn't
work. Has the 300 series stopped being supported by any means?
Intel(R) Driver Update Utility 2.2 wasn't able to find the right driver for my system
either. It finds this file to download: Intel chipset device software (INF Update
Utility-exe only) version 10.0.27 date 5/7/2015
After installing it successfully i see Status: Failed (!!) and after the restart i
have to repeat the procedure from the top with the same results..
So driver update utility doesn't work either..
I have a GPU integrated in my MB which failed recently and i repaired temporarily but it
won't last for long. I want to stop using it and use the integrated GPU of my i3 330M
processor instead. I figured this would be possible installing the driver above.
Could you help me please? Is there anything else i can do? Thank you in advance!!
Intel(R) Processor Identification Utility
Version: 5.30.20150729
Time Stamp: 2015/08/20 07:07:26
Operating System: 6.1-7601-Service Pack 1
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 2
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM) i3 330M CPU @ 2.13GHz
Type: 0
Family: 6
Model: 25
Stepping: 2
Revision: E
Maximum CPUID Level: B
L1 Instruction Cache: 2 x 32 KB
L1 Data Cache: 2 x 32 KB
L2 Cache: 2 x 256 KB
L3 Cache: 3 MB
Packaging: µPGA/BGA
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Intel(R) AES-NI: No
Intel(R) AVX: No
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: Yes
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: Yes
Intel(R) VT-x with Extended Page Tables: Yes
System Graphics: Add-in Graphics
Expected Processor Frequency: 2.13 GHz
Reported Processor Frequency: 2.13 GHz
Expected System Bus Frequency: 133 MHz
Reported System Bus Frequency: 133 MHz
