23807 Discussions
Problem installing RST
So I have a bit of an older but very good mobo. Gigabyte GA-965P-DS3 version 1. It has one of the latest bios with AHCI enabled.
I picked up a Corsair F60 SSD week back, installed Windows 7 on it but it installed msahci driver. I tried installing the latest RST and it says my system does not meet the minimum requirements. Tried to install the drivers manually by adding my hardware id to the inf files and it wouldn't install. When I forced it to install by manually selecting the driver it bluescreened on me.
I know I installed the RST drivers before with my old setup of WD black drive.
I believe my mobo uses an ICH8 controller. Any insight as to what I can do to get it to install. Even running the latest rst driver on the intel site for my chipset gives me same minimum requirement error.
Do you have the SSD in one of the yellow ports?
Is "SATA AHCI Mode" set to AHCI and "SATA Port0-3 Native Mode" set to enable?
