23787 Discussions
Problem outputting to Extended Monitor
I just installed Windows 7 on a computer running the Asus P8H77-V. I installed the Intel HD Graphics driver and ran all Windows updates.
My problem is that I want to drive two NEC AS221WM monitors using the graphic outputs on the Asus motherboard.
My problem is that as soon as I set the resolution of both monitors more than 1360 x 765 output appears only on one of the monitors.
How can I fix this please?
I'm attaching the System Information
Intel(R) HD Graphics 2500
Report Date: 12/20/2012
Report Time[hh:mm:ss]: 17:30:47
Driver Version: 9.17.10.2875
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (United Kingdom)
DirectX* Version: 11.0
Physical Memory: 11980 MB
Minimum Graphics Memory: 256 MB
Maximum Graphics Memory: 1760 MB
Graphics Memory in Use: 101 MB
Processor: Intel64 Family 6 Model 58 Stepping 9
Processor Speed: 3502 MHz
Vendor ID: 8086
Device ID: 0152
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 2500
Video BIOS: 2143.0
Current Graphics Mode: 1360 by 765
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 2
* Digital Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 18.50 inches
Vertical: 11.81 inches
Monitor Supported Modes:
640 by 480 (67 Hz)
640 by 480 (75 Hz)
640 by 480 (72 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
832 by 624 (75 Hz)
1024 by 768 (75 Hz)
1024 by 768 (70 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 1024 (75 Hz)
1280 by 1024 (60 Hz)
1280 by 720 (60 Hz)
1280 by 960 (60 Hz)
1360 by 765 (60 Hz)
1400 by 1050 (60 Hz)
1440 by 900 (60 Hz)
1680 by 1050 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 38 A3 C2 67 01 01 01 01
0E 15 01 03 80 2F 1E 78 EA 27 65 A5 54 4A 99 24
12 50 54 BF EF 80 81 C0 81 40 81 80 8B C0 95 00
90 40 B3 00 71 4F 21 39 90 30 62 1A 27 40 68 B0
36 00 D9 28 11 00 00 1C 00 00 00 FD 00 38 4C 1F
53 11 00 0A 20 20 20 20 20 20 00 00 00 FC 00 41
53 32 32 31 57 4D 0A 20 20 20 20 20 00 00 00 FF
00 31 33 31 32 39 31 31 33 54 42 0A 20 20 00 E4
* Digital Display 2 *
Gamma Value: 2.2
Maximum Image Size:
640 by 480 (67 Hz)
640 by 480 (75 Hz)
640 by 480 (72 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
832 by 624 (75 Hz)
1024 by 768 (75 Hz)
1024 by 768 (70 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 720 (60 Hz)
1280 by 960 (60 Hz)
1360 by 765 (60 Hz)
1440 by 900 (60 Hz)
Raw EDID:
00 31 33 31 32 39 31 32 36 54 42 0A 20 20 00 E0
* Other names and brands are the property of their respective owners.
DArce
Valued Contributor III
I will review if there is any limitation on this particular configuration.
While doing this, could you please specify if this happens while using Clone mode, Extended desktop or both? In addition, have you tried using a different model of display on any of the other ports? What ports are bieng used and what is the port that continues working?
Hi Diego,
This happens when I use Extend mode. I set the resolution of both monitors more than 1360 x 765 output appears only on one of the monitors. The ports I am using are DVI and HDMI. On the Asus board the other port is VGA. I have not used this.
Allan_J_Intel1
Hi Alan,
I'll like to follow up on this matter, please check couple of questions I have for you below:
What type of video cable are you connecting this monitor? Is it HDMI to HDMI, or VGA to HDMI or DVI?
Was the computer BIOS updated? What is the version of it?
Allan.
I have an HDMI to HDMI cable and a DVI to HDMI adapter that in turn is plugged into another monitor via HDMI. Both HDMI cables have been verified to work well.
I have compiled a short video on youTube describing the problem, It can be seen at http://youtu.be/RNLZDrmfA44 Problem outputting to Extended Monitor (Asus P8H77-V M/board with on Board Intel Graphics) - YouTube.
Can someone please confirm whether the intel graphics chipset is limited and therefore unable to handle such high resolutions.
