23762 Discussions
Problem updating hd4000 drivers
llol
I get this message when trying to update my hd4000 drivers "this computer does not meet the minimum requirements for installing the software"
I have a dell inspiron 5520 with windows 8.
Kevin_M_Intel
Hi lizardwaffles,
Based on your information I recommend you installing the latest graphics driver for your computer. It is important to mention that Intel® provides the generic driver for OEM systems and due to this reason you have two ways to install the driver in your computer.
You can try with the .exe file that can be downloaded at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers
In the case you still have the error you can try the other step that is to try with the manual driver installation. You can check the steps at the following link:
http://www.intel.com/support/graphics/sb/CS-022355.htm http://www.intel.com/support/graphics/sb/CS-022355.htm
