23784 Discussions
Problem with FIFA 17, need driver update
MGijo
Hi guys, I've seen an update for the 4th generation of Intel graphics, but it's only for win7 and win8. It seems to fix the ''fifa 17 corruption'' problem. I'm suffering this issue, but in Windows 10. I tried every new driver (including beta 15.40.xx.4539), every kind of config in Intel's control panel, etc. My issue is that it crashes and the textures bug during the gameplay.
My question is, can you release this driver for windows 10?
MSchm21
Valued Contributor I
MGijo
Hi, thanks, gonna try it. One question, where did you find it? I've never seen that driver on Intel's page.
MSchm21
I was looking for the newest 15.40 driver here https://forums.laptopvideo2go.com/forum/198-1540xx-201915xxxx/ 15.40.xx (20.19.15.xxxx) - LaptopVideo2Go Forums
It's a test driver, maybe that's why it isn't listed.
Hello marcosgijon,
What is your processor model?
Ivan.
MGijo
Hi Ivan, my model is i5-4570R
Please try this driver version:
https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-
If you get an error installing this driver, uninstall the old one and try installing it manually, please check how to http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*
Please let me know.
Ivan.
MGijo
Hi, as I mention in my post, I've already tried this driver, and it gave no solution.
Being that the case, please fill out the information at the following link to further investigate the issue.
Also, to better assist on this, would you please fill out the information at the following link?
/thread/77761 https://communities.intel.com/thread/77761
Please don't forget to attach the system information with the latest graphics driver installed:
Intel SSU (System Support Utility) (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility😞
Download Intel® System Support Utility
  1. Download the utility
  2. Run the exe and select 'Scan'
  3. Save and include as an attachment in the Intel Community Forum
Please provide with the Report for Intel® Graphics Drivers follow the steps here:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html
DxDiag Instructions:
  • Click on the "Start Menu" -> Type "DxDiag" -> Press "Enter" -> Wait for the DirectX Diagnostic Tool to finish loading
  • In the DirectX Diagnostic Tool, click "Save All Information" -> Save the file DxDiag.txt
  • Include DxDiag.txt as an attachment in the Intel Community Forum
DispDiag Instructions:
  • Click on the "Start Menu" -> Type "cmd" -> Then a command shell window will open
  • In the command shell, type "dispdiag –out %homepath%\Desktop\DispDiag-Intel-Issue.dat" -> The command shell will output something similar to "Dump File: C:\Users\[username]\DispDiag-# -# -# -# .dat"
  • Locate the .dat file on your desktop and include DispDiag-Intel-Issue.dat in the Intel Community Forum
Ivan.
Hello ,
I'm following on this post to ask you if could fill out the information requested above to better assist you.
Ivan.
