23831 Discussions
Problem with Graphics HD 4000/Display Adapter
LTruo2
So to begin with, when I updated to the newest Windows 10 point something, the brightness controls weren't working. After some research, I found that there was a glitch in the new update and the only way to fix it was going back to the old version. In order to do that, I had to uninstall the full Intel Graphics Driver but when I try downloading the new (I guess technically old) Graphics Driver, it says "Your computer does not meet the minimum requirement to install this". After a little more research, I think I found my problem. Instead of seeing "Basic Microsoft Display Adapter" under Display Adapters in Device Manager, I don't even have a display adapter period.
How do I fix that?
I have a
Lenovo Ideapad P400
64 OS
THowe1
Try this: http://download.lenovo.com/consumer/mobiles/1hvh14w8.exe Intel Video Driver for 64-bit Windows
Got it from here: http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS034266 Drivers and software - IdeaPad P400 Touch Notebook
(For Windows 8 64-bit) Download and install it. If I got you're OS wrong you can go to that website and select the right one.
Post back if you have any issues!
Jose_H_Intel1
Perhaps it is showing up in "Other devices" or "Unknown device".
You may try the manual installation method or Windows* System Restore.
http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
LTruo2
Joe, thanks for your reply but I tried both options and I am still getting the "Your computer....install this" message and I still can't find the display adapter in "other devices" or "unknown device". Any more advice?
Jose_H_Intel1
Please provide the System Information report (press Windows* key + R, type "msinfo32", press OK and then Export).
THowe1
LTruo2
Downloading the driver worked! Before when I tried downloading, I got the same "Computer is not compatible" message but after the System Restore, it worked perfectly, thanks!
THowe1
No problem, glad to help.
JReyn7
Intel HD Graphics 4000 and Windows 10 & Windows 8.1 ( Brightness fix with latest driver)
Brightness Fix with Driver Date 8/17/2015 )
Brightness problem Solved
Intel HD Graphics 4000 with NVIDIA® GeForce® GT650M graphics.
Install:
Intel HD Graphics 4000 Driver, Driver Date: 8/17/2015
Driver Version: 10.18.10.4276
Make sure you backup your registry first before proceeding!!!!
open regedit in Run Command
Registry has wrong value:
Currently reads as :
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000] "FeatureTestControl"=
"Edit DWORD 32 bit"= f000
Registry with New Value:
You needed to change the value in registry to: ( f008 )
"Edit DWORD 32 bit"= f008
Then Restart Computer
Brightness Fixed with Latest driver.
Let me know if this was helpful to you
mailto:[email protected] [email protected]
