23812 Discussions
Problem with Intel HD 3000 Driver Updation .
tmaht1
Hello
I use DeLL Inspiron N5110. Anytime I try play CoD BO 1 , I got this error
"display driver stopped responding and has recovered".
I serach the Internet to Solve this Problem I found that New Version of Driver for Intel HD 3000 is available ,So first I Download the Zip file When I try to Update my Driver I got this Error
"Your computer does not meet the minimum requirement for installing the software."
So I download the Exe File form your download center After updating my Driver I found that I have still the same Version (9).
I tried Every possible solution available for me .
The Driver I tried is listed below
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23764&lang=eng&ProdId=3319 Intel® Download Center
Need Help
Here is the DXDiag
System Information
Time of this report: 8/6/2014, 13:36:56
Machine name: Dell
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_gdr.140330-1035)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron N5110
BIOS: BIOS Date: 08/03/12 11:06:40 Ver: 04.06.04
Processor: Intel(R) Core(TM) i3-2310M CPU @ 2.10GHz (4 CPUs), ~2.1GHz
Memory: 4096MB RAM
Available OS Memory: 4004MB RAM
Page File: 2257MB used, 5841MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 3000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_04B01028&REV_09
Display Memory: 1664 MB
Dedicated Memory: 32 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (40Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD02DC
Native Mode: 1366 x 768(p) (59.992Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.3517 (English)
Driver Version: 9.17.10.3517
DDI Version: 10.1
Feature Levels: 10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Driver Attributes: Final Retail
Driver Date/Size: 3/20/2014 08:40:48, 12617728 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4256-11CF-257E-BA24B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0x04B01028
Revision ID: 0x0009
Driver Strong Name: oem28.inf:5f63e534c4a6341c:iSNBM0:9.17.10.3517:pci\ven_8086&dev_0116
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Forma...
tmaht1
bumb I think no one interested to answer my Question
Silvia_L_Intel1
Hello Tham12, I really sorry for the inconvenience that you have faced with your system and the graphics driver.
There is a great explanation on the following thread from my coworker Allan. Please check this out since I think that user was having the same issue.
tmaht1
hey sylvia_intel
thanks for the reply I go through the thread you provided but My laptop have only one graphic Card that is Intel HD 3000. I try all the Driver Provided in Download Center I keep getting this msg on three Driver Version except 64 bit .exe but When I update the Driver I found that I have still the same previous Version .I also Try to instal manually instal of Driver but Failed ?????? wt to do Now ?
tmaht1
Silvia_L_Intel1
Please check the following URL. It will give you some steps you can follow in order to solve the error you are getting "System does not meet minimum requirements"
http://www.intel.com/support/graphics/sb/CS-034659.htm http://www.intel.com/support/graphics/sb/CS-034659.htm
tmaht1
this is nt the solution to my problem ,Very poor support by intel
Silvia_L_Intel1
Tham12, I really sorry but since our drivers are generic, some computer manufacturer does not allow the installation of them.
