23710 Discussions
Problem with Intel HD Graphics and VGA output
I am trying to get the VGA output to an external monitor to work.
I am connected to my monitor directly using a standard VGA cable.
I am trying to enable primary display to the external monitor: I only get a black screen. The monitor says it is not receiving a signal.
When I try to clone or extend the display: same results.
Here is my setup:
Monitor: Iiyama ProLite E2710HDS
Operating System: Windows 7 Professional 64bit w/ Service Pack 1
Laptop: Thinkpad T420
Graphics Adapter Info:
Intel(R) HD Graphics 3000
Report Date: 1/11/2012
Report Time[hr:mm:ss]: 10:27:8
Driver Version: 8.15.10.2538
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (United States)
DirectX* Version: 10.1
Physical Memory: 3979 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 88 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 2491 MHz
Vendor ID: 8086
Device ID: 0126
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2089.0
Current Graphics Mode: 1600 by 900
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: ThinkPad Display 1600x900
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 12.20 inches
Vertical: 06.69 inches
Monitor Supported Modes:
1600 by 900 (50 Hz)
1600 by 900 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 AE A1 40 00 00 00 00
01 14 01 03 80 1F 11 78 EA CC CE 99 58 50 8E 26
24 4B 53 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 F8 2A 40 9A 61 84 0C 30 40 2A
33 00 35 AE 10 00 00 18 CF 23 40 9A 61 84 0C 30
40 2A 33 00 35 AE 10 00 00 18 00 00 00 0F 00 A9
09 32 A9 09 32 19 09 00 06 AF 56 31 00 00 00 FE
00 42 31 34 30 52 57 30 32 20 56 31 20 0A 00 7B
Stephane B.
Note: the external monitor works fine with my desktop computer and with a T400 laptop.
DArce
Valued Contributor III
We have tested the latest generic driver for this video controller, driver version 8.15.10.2509 and no similar issues have been seen or reported.
You can try using that generic driver and see if the issue persists. The driver is posted here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Processor+graphics&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000&ProdId=3319&LineId=3310&FamilyId=39 http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Processor+graphics&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000&ProdId=3319&LineId=3310&FamilyId=39
You can also try updating your system BIOS and test setting the VGA monitor as the only active display (not using the integrated display of the laptop).
Test also leaving the VGA monitor connected and restart the computer. Check if there is any image on the VGA display if you enter the system BIOS and during the system boot up. Furthermore confirm if the VGA display is listed in the Device Manager and in the system report at the Intel(R) Graphics and Media Control Panel when it is connected. (Pretty much it is since the graphics driver console would not give you the option to do clone or extended if another display is not connected, but this would be just to double check).
Additionally, you might try using another model and manufacturer of display and try using a previous version of the driver provided by your computer manufacturer.
If the issue persists, I suggest you to check directly with your computer manufacturer to see if the hardware in your system and the software installed are working properly.
Thank you for taking the time to reply.
I had already tried the "generic" Intel driver you mentionned after completely uninstalling the device driver from device manager: without success.
I have tried another monitor from a different manufacturer: no luck.
To eliminate the device driver as a possible cause, I tried booting from an Unbuntu boot CD: no luck.
I have enabled boot display on the VGA port in the BIOS: screen remains black.
I am suspecting that the VGA port on my brand new Lenovo Thinkpad T420 is simply not working at all.
Stephane B.
Most definitely a hardware problem (malfunctioning VGA port).
