23769 Discussions
Problem with driver installation
Hi,I am looking for help to try and solve a driver problem,I hope that someone may be able to help.
The problem concerns Mobile Intel (R) 965 Express Chipset Family.
Display Adapters:Message in device status.
This device cannot find enough free resources that it can use. (code 12)
If you want to use this device, you will need to disable one of the other devices on this system.
I cannot find a solution to this problem.
This problem is on an ACER ASPIRE 5315
OS=VISTA HOME PREMIUM 32 BIT
Any help would be much appreciated,thanks.
Allan_J_Intel1
Hi,Alan many thanks for the info I will give it a try and see if it solves the problem.
I have still got the same problem Alan,nothing has changed.
The driver I am looking for is Chipset Intel v.8.2.0.1014 Vista x86 but I do not seem to be able to find it. This driver worked perfectly until it was updated now I can't play games anymore.
