23845 Discussions
Problem with graphics drivers
OKons
I have a HP Pavilion g6-1265sa with Pentium B950 in it. When I download graphics drivers then after restarding there will be lines made of black and white dots. After deleting graphics drivers there aren't any dots(it has Intel HD Graphics 2000 in it. My question is, how can I install graphics drivers without getting those dots on my screen?
AlHill
Are you using WIndows 10? If so, HD 2000 graphcs and your CPU are not supported.
Doc
OKons
I'm using Windows 7 Pro 64 bit.
AlHill
try the latest driver hereL
https://downloadcenter.intel.com/product/81503 Downloads for Intel® HD Graphics for Previous Generation Intel® Processors
doc
OKons
When i try to install it says computer does not meet minimum system requirements.
AlHill
One of the Intel support staff may be able to help you with this error.
Doc
OKons
Oh i think older version will do i didn't see those. But thank you for help!
AlHill
I would try the driver from the HP website.
Doc
OKons
I think i've tried and they haven't worked.
OKons
And older drivers still had dots on screen.
OKons
But i have few more questions. May changing thermopaste work? Or buying a new cpu?
AlHill
Do not start messing with the processor. And, as old as your machine is, upgrading the processor would not buy you much. Also, you would have to have HP tell you which processors are supported by their BIOS.
If you are serious about upgrading, I would recommend you look at something current, that is fully supported. Unfortunately, this means getting rid of what you have. So, consider the pros and cons before doing so.
Doc
