23676 Discussions
Problem with rotation in clone mode
AMezh
My situation. I have 2 connected displays, made working them in clone mode. From time to time I rotate main display by 180 degrees. When I do this, respectively, image on slave display rotates as well, but I don't need it, I want the image on 2nd display to keep its original orientation.
How could I solve this issue? Is it possible to find a programmer, who will write a small programm, that will hold secondary display's position?
Thanks, Alex
Filip_Z_Intel
Please switch to Extended mode. Then You can rotate one display and keep the other one unchanged
Filip_Z_Intel
AMezh
The problem with this mode is so, that the 1st display is going to be controlled with touchscreen only, so there is no control on 2nd display, when it is in extended mode.
