23801 Discussions
Problema
KZold1
  1. Hi Intel I'm facing problem while playing Crossfire AL every time I get to play for a while and then the game crashes more this running but the image is locked and I already tried to install update drive but it did not work my video drive and Intel can help me?
Stefan3D
You provided no system info. Upload a report from https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility for Windows* for more help.
KZold1
Stefan3D
I see Intel forgot to update drivers for your N2808 in the download center.
This driver supports your Baytrail (Valleyview) GPU
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
Also in your device manager there is a yellow bang for the memory controller (?) that needs to be fixed.
Double-click it for more info.
KZold1
Hello again I tried to do what this asking in the Application manager and this error
KZold1
Stefan3D
Códigos de erro no Gestor de Dispositivos no Windows
https://support.microsoft.com/pt-pt/help/310123/error-codes-in-device-manager-in-windows https://support.microsoft.com/pt-pt/help/310123/error-codes-in-device-manager-in-windows
O código 18 "reinstale os controladores para este dispositivo. (Código 18)"
Resolução recomendada
Reinstale o controlador de dispositivo utilizando o Assistente de actualização de Hardware
  1. Desde o início, procure o Gestor de dispositivos e seleccione Gestor de dispositivos a partir dos resultados.
  2. Botão direito do rato no dispositivo na lista.
  3. No menu que aparece, escolha Actualizar controlador para iniciar o Assistente de actualização de Hardware.
Reinstalar o controlador de dispositivo manualmente
  3. Seleccione desinstalar a partir do menu que aparece.
  4. Depois do dispositivo é desinstalado, escolha a acção na barra de menus.
  5. Seleccione Verificar alterações de hardware para reinstalar o controlador.
Nota Poderá ser solicitado que forneça o caminho do controlador. Se lhe for pedido o controlador e não o tiver, pode tentar transferir o controlador mais recente do Web site do fabricante de hardware.
KZold1
Bom fiz oque pediu e e o erro no gerenciador persiste
