23778 Discussions
Problems with 3D Panel
AMaic
Hi guys, i have Intel i3 with Intel HD Graphics.
When i try to enter in 3D section in panel:
Stefan3D
Did you already install latest driver for your rig?
Looks like the same issue mentioned at:
Reply # 13 claims:
"I would like to confirm that we already have a fix for this issue. This is currently being retested and our goal is to incorporate it in our next driver updates."
AMaic
How i install latest driver?
Stefan3D
Either select manually a driver from the sticky topics in this forum or use the https://downloadcenter.intel.com/download/24345/Intel-Driver-Update-Utility?product=79577 Intel® Driver Update Utility
Hello alexyus,
I understand you are having troubles accessing the 3D section of the Intel Graphics Control Panel.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Does the issue happen only with the 3D section of the Intel Graphics Control Panel?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Hello alexyus,
I was wondering if you still need assistance regarding the 3D section on the Intel® Graphics Control Panel. In case you still need assistance just let me know.
Fred D.
