23764 Discussions
Problems with Intel Core I3-1110 U setting resolution
Kevin20
Hi, I have a new computer, a Lenovo V15 G1 IML. In this computer, I have an Intel Core I3-1110U processor and Intel UHD Graphics. In theory, the maximum resolution I can use is 4096 x 2304 x 60 Hz with the display of the notebook, but I can't change it. The maximum resolution the system allows me is 1366 x 768. I tried to change it in the system settings and in the Intel graphics center, but I don't have the option. Also, I tried to personalize the resolution setting, but the graphics center denied my attempt with something like "not compatible with the mode".
I attach photos to see better what I'm talking about.
Is there any solution to change the resolution?
Thanks you all!
Jean_Intel
Hello Kevin20,
Thank you for sharing on the Intel® communities. We are happy to assist you in any way we can.
You are correct that the maximum supported resolution for your integrated graphics is 4096 x 2304 x 60 Hz. Please note that to achieve this resolution, your monitor should also support this resolution. We found this information about the specification of the Lenovo V15 IML products. In the display section, they mentioned that the supported resolutions are HD (1366x768) or FHD (1920x1080), depending on the model.
Jean O.
Jean_Intel
Hello Kevin20,
Jean O.
Jean_Intel
Hello Kevin20,
We hope you are doing fine.
Jean O.
Kevin20
Thanks Jean! I have the HD model, that's why I can't improve the resolution.
Jean_Intel
Hello Kevin20
We are pleased to hear that the provided information was helpful. It is our hope that it will also benefit other members of the community. As the issue has been resolved, we will now proceed to close the thread. If you need any additional information, please submit a new question since this thread will no longer be monitored.
Jean O.
