23851 Discussions
Problems with collage profile
JP_
Hello!
We have a fujitsu P556 / 2 computer that brings an integrated 630 intel, because our client has asked us to put two external screens to show videos and a monitor where we can work, we put the following configuration:
Intel 630 -
DP - 1 TV (with a DP-VGA adapter)
HDMI direct to TV
Nvidia 210 for main monitor (principal monitor for windows 10)
in the control panel configure the two TVs in mod collage
Once configured everything works perfectly ... until the TVs are turned off! when turning them on again everything is unconfigured, the TVs are put in normal mode and it is predetermined, I have to reconfigure the control panel with a saved profile called COLLAGE TV
Is there a way to tell the control panel that this profile is always predetermined, that it does not change the configuration and always use this profile?
I have the latest version of the driver, the 15.65, Windows 10 Professional 1709
regards
Hello TenicoHard
Thank you for joining the community.
In order to help you better, I would like to gather more information about the configuration you have on the computer. Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Steps to save the report:
  1. Run the utility
  2. Click on "Scan" to get the scanned system
  3. Once the scan is complete click on "next"
  4. Use the "save" option, save the report to your desktop.
  5. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Could you verify if the system supports hybrid graphics if it is supported, is the feature enable? For assistance on the hybrid graphics configuration, we recommend contacting the Fujitsu the system manufacturer.
Leonardo C.
Hello TenicoHard
I was checking your case and would like to know if you were able to obtain the report.
Leonardo C.
RoGl
I have almost the same problem. When the monitors restarted (switched off for the night), the collage configuration is gone.
