23806 Discussions
Processor Graphics 3000 not compatible with OpenGL last version
The scientific 3D reconstruction software, Seg3d2 (ver 2.1.2 64bit for windows), doesn't start in windows7 PRO with core i7 and "Intel HD Graphics Family, Processor Graphics 3000", running on a "ASUS ZENBOOK, motheboard UX31E".
The program is launched on the laptop, the starting process icon appears for about 5-6 sec and then it stops and nothing happens; the process is kicked off (as is confirmed looking at the "Windows Task Manager" panel).
May the problem be due to the non-compatibility of the "Intel Processor Graphics 3000" driver with the last version of OpenGL?
Thank you for any help.
DArce
Valued Contributor III
Hello Fonda99,
I would like to let you know that your feedback has been forwarded to our development team and they are investigating this issue.
At this moment, we cannot provide an estimated time for us to provide a complete answer this, but be sure that our software support and engineering group are aware of your issue and they are actively working on this.
We appreciate your patience on this matter.
Hi Diego,
My app is a visual studio 2008, c++ app with opengl and glut (not finished yet).
You can also replicate the same problem with the following links
http://nehe.gamedev.net/data/lessons/vc/lesson07.zip http://nehe.gamedev.net/data/lessons/vc/lesson07.zip
or
http://nehe.gamedev.net/data/lessons/vc/lesson10.zip http://nehe.gamedev.net/data/lessons/vc/lesson10.zip
You can use exe file in the zip.
The problem is in the full screen mode. Resolution change is unimportant I guess (my app has the same resolution with the desktop).
Thanks...
Re - But, at this time, I cannot use alt+tab or windows+tab (before this driver, it was possible). If I use, focus is gone, but wrong window (my opengl app) is shown in front. Real trouble. Then I have to use ctrl+alt+del to escape.
This behaviour is still present for full screen openGL apps with current driver revision 8.15.10.2696 (Win 7 64bit, core i5 2430m, HD3000)
Bug still present with 8.15.10.2761
I have Dell laptop with intel (R) HD graphic 3000 core i3 2nd generation the driver Version is the latest one 9.17.10.2875 and it cann't open medal of honor
and the os is win 7 -32bit
Hello Diego from Intel
How do I get my OpenGL (OGL) to be supported by my graphics card driver (integrated chip), I have Intel® 82852/82855 Graphics Controller Family for the 845g. The graphics chip driver supports up to 1.4 and nesecito that supports OGL 2.0 at least (there is already OGL 4.2). I noticed that the OGL 1.4 has almost 10 years (July 24, 2002) and not think it's possible the idea that PC did not update the drivers for the 845G chip family. The problem issue is because I can not run warzone2100 3.x (either beta or not) because the driver does not support OGL 2.0 as mentioned above.
I want you to please update the driver, it's of vital importance to my busyness.
AP16
anonymous2303
Your IGP havn`t hardware functions needed for OpenGL 2.0 support, so there is no driver solution for you.
Hello. I have Intel Hd Grpahics 3000 and i just updated to the latest update for this graphics driver thinking it would support OpenGL 3.1...... sadly i tried to load my game that usues OpenGL 3.1 and it gave me the same error saying that my grpahics driver did not support 3.1...... i was wondering if others have gotten this same problem even though they updated. Does the new update have OpenGL3.1 support?
heres the error: (colored it green)
--------------------------------------Loaded 3798 manifest elements in 12 ms - 193KbDiscarded 0 manifest elementsMax filename length: 0 charactersBrink 1.0.23565.48095 win-x86 Jul 13 2011 12:04:09couldn't exec 'brinkconfig.cfg'couldn't exec 'autoexec.cfg'Vendor: 8086 Device: 01162195 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & HTT8 logical cores4 physical coresHT enabled6064 MB System Memory512 MB Video MemoryInitializing performance queriesDetected 4 2.20 GHz CPU6064 MB of System memory512 MB of Video memory on an optimal video architecture This system qualifies for High quality!Vendor: 8086 Device: 0116Winsock InitializedFound interface: {F35463D5-8770-4DC8-A88A-864933D14DC9} Microsoft Virtual WiFi Miniport Adapter # 2 - 0.0.0.0 NULL ip - skippedFound interface: {C27E6D14-BBEE-4F54-B257-70B4DA5D59BE} Microsoft Virtual WiFi Miniport Adapter - 0.0.0.0 NULL ip - skippedFound interface: {B263A3BA-E1C2-47E8-B410-31D0A6018817} Intel(R) Centrino(R) Wireless-N 6150 - 192.168.1.73/255.255.255.0Found interface: {889408A1-14E6-4B09-B31B-EADC72335A13} Intel(R) Centrino(R) WiMAX 6150 - 0.0.0.0 NULL ip - skippedFound interface: {3AA2EF61-3758-407C-8FA3-45A15F02C26A} Realtek PCIe GBE Family Controller - 0.0.0.0 NULL ip - skippedSys_InitNetworking: adding loopback interface--- Loading sequence: init ---sound index file 'generated/preload/sound/pc/english/init.soundpreload' is zero length------- Initializing render context --------Initializing OpenGL subsystem...calling LoadLibrary( 'wtsapi32.dll' 😞 succeeded...initializing Windows Terminal Server API...registered window class...registered fake window class...calling LoadLibrary( 'opengl32' 😞 succeeded...initializing QGLGL_VENDOR: IntelGL_RENDERER: Mobile Intel(R) HD GraphicsGL_VERSION: 3.0.0 - Build 8.15.10.2353********************FATAL ERROR: The current video card / driver combination does not support OpenGL 3.1 or newer.********************The current video card / driver combination does not support OpenGL 3.1 or newer.Shutting down OpenGL subsystem...releasing DC...resetting display...shutting down QGL...unloading OpenGL DLL...unloading Windows Terminal Server API DLL
plus i cant seem to fully update my graphics driver withour an error!
Hello there - I had an Issue using Blender 3D with INTEL HD 3000 (Blender is OpenGL-based) - I had this known Window-redraw issue with my new Ultrabook.
What I tried was using an older driver (Version: 8.15.10.2509) and now it works perfectly.
Maybe it helps with your Issues as well?
the driver can be found here - > http://downloadmirror.intel.com/21231/a08/Win7_64_15268.exe http://downloadmirror.intel.com/21231/a08/Win7_64_15268.exe
cheers - benjamin
