23466 Discussions
Q: Verify and repairing repeats...
Our area had a power outage last night and the system shutdown unclean (UPS didn't run long enough to keep the system going and I didn't have it setup to shutdown on low UPS battery). Anyways, the machine rebooted and has been "repairing and verifying" the RAID-1 array since it came back up last night. I watched it this morning as it approached 100% completion; no errors found. Once it hit 100% it restarted the entire process again.
This is obviously not normal?? If not, what should I/can I safely do to stop it.
Thank you.
