23828 Discussions
Q965 Dual Monitor default setup
I'm trying to get an unattended installation of the Q965 driver which will set the correct defaults for my monitor configuration.
At the moment the unattended install (XP) selects one of the monitors as primary and does not enable the second. Is there a method of automatically loading a profile setup that will swop and configure the monitors resolutions settings?
Hope you can help
Mike
Allan_J_Intel1
Hi there!
Intel does not support unattended installations because this is a customization of your system but depending on the graphics driver version you can try scheme mode features.
See this URL for more information:
http://www.intel.com/support/graphics/sb/CS-020995.htm http://www.intel.com/support/graphics/sb/CS-020995.htm
Allan.
