23784 Discussions
Question about intel hd graphics 530
АЛебе
Good afternoon. There is a problem with intel hd graphics 530.
This video card, integrated in Intel Cor processor i7-6700HQ ASUS N52VW laptop
This notebook has a recommended screen resolution of 384x2160, but at this resolution the screen twitches. At any other (lower) such a problem is not observed.
Drivers are the latest both on the video system and on the chipset
Video - 21.20.16.4550
Windows 10 Corp
32Gb RAM (16+16)
Hello dronsky,
Thank you for contacting Intel Communities.
In this case, there is a new graphics driver version that was released on 03/23/2017.
https://downloadcenter.intel.com/download/26669/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=88345 Intel® Graphics Driver for Windows* [15.45] Version: 15.45.16.4627 (Latest) Date: 3/23/2017
Please try installing that driver and let me know how it goes.
JC
АЛебе
Good afternoon, thank you for responding so quickly.
Unfortunately these drivers have the same problem.
The screen flickers at 4K resolution.
There are no other solutions to this problem.
Hello dronsky,
Can you please test the system without any graphics drivers (use the generic Microsoft drivers)?
Follow http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html these steps to uninstall the current graphics driver.
Please let me know if the issue persists.
JC
АЛебе
Good afternoon, Intel Corporation!
Yes. I did that. On the standard VGA drivers from Microsoft.
No standard flicker observed
Hi dronsky,
As the last troubleshooting step, I would recommend updating the BIOS of your laptop (contact Asus for further information) and also install the following driver and let me know how it goes:
https://downloadcenter.intel.com/download/25620/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40-6th-Gen-?product=88967 Intel® Graphics Driver for Windows® 7/8.1/10* [15.40 6th Gen] Version: 15.40.14.4352 (Latest) Date: 12/23/2015
JC
АЛебе
Unfortunately the BIOS update did not save the situation either. The only thing is that ASUS garnits the laptop with 16GB of RAM, and I installed 32 GB. 16 GB works without problems.
Driver installation did not help (https://downloadcenter.intel.com/download/25620/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40-6th-Gen-%3Fproduct%3D88967 Intel® Graphics Driver for Windows® 7/8.1/10* [15.40 6th Gen] Version: 15.40.14.4352 (Latest) Date: 12/23/2015)
Hello dronsky,
Thank you for the information.
I couldn't find information about your system with this model number ASUS N52VW, but I found information on this one https://www.asus.com/Notebooks/VivoBook-Pro-N552VW/specifications/ VivoBook Pro N552VW, and per these specs, it supports only up to 16 GB. If this is your system then, this may be causing the display issues. You will need to confirm the RAM support with Asus.
JC
After reviewing your case, I was wondering if you contacted Asus and checked memory information.
Thank you for your time.
Allan.
АЛебе
Good day, Intel Corporation
Yes, I contacted the ASUS. They answered that this system was tested only on 16 gigabytes of RAM. With higher than 16 GB they do not guarantee stable operation of the system
Thank you for the timely replies! Tickets can be closed.
Hi dronsky,
Thank you for letting me know. Please don't hesitate in contacting us back if you need further assistance.
JC
BJurg
I have a ASUS desktop and had graphical interference with the HD graphics 530. I may have found the solution (it was on the Internet). I set my Power Option to "High Performance". (i.e. Control Panel, Power Options, [you may have to UnHide Advanced options], then select "High Performance"). The graphical corruption of tearing went away immediately, the flickering in the Microsoft games (i.e. solitaire, mahjong, minesweeper) stopped.
Hope this helps. Notebook users will note that this will diminish battery life.
BTW I had gone through several Intel HD graphics 530 driver versions. I am currently on version 15.45.18.4664.
