23832 Discussions
RAID migration problem
I have a two disk raid array (raid 0) contianing DATA; the main disk in this machine ahs failed so cannot boot etc. I am installing a new machine using Intel i7 with chipset 55.
Can I move the RAID disks to teh new PC and 'import' the configuration without losing any data on tehm?
thanks
So just to be clear two disks in RAID 0 and one drive for the OS?
If you install the OS on its own drive and as long as you enabled RAID first and that the RAID was a ICHxxR on the old machine, you will be able to connect the drives to the P55 SATA ports and access your RAID 0.
Peter
thanks for this
Yes, it is one disk for OS and two seperate disks for RAID; the existing RAID is ICH7R (so only one 'X" - does his matter?).
When you say '..RAID was enabled first...' do you mean before the OS is installed or before the two RAID disks are installed or have I missed soemthing else?
many thanks
Nope I went from a ICH8R to P55 ICH7R will do the same.
Yes
I did this and it set all three disks (my two recovery ones and the exisitng boot disk) to RAID - this diabled booting form the boot disk!
How can I:
set jsut two of three SATA disks to RAID
OR
recover data from two RAID 0 disks not recognised as RAID??
You lost me if it disables booting form a boot disk when set to RAID how would anyone setup a RAID.
