23850 Discussions
Radeon RX Vega M random dimming
i have the following issues:
The brightness of my PC is changing on random occasions. Normally a few minutes after I start the PC the brightness gets dimmed. but then a few minutes or even hours later it gets brighter again and the whole cycle begins from the start..
adaptive brightness in Windows and in the TV settings is already set to off. Also automatic adjustments of contrast has been set to off.
Hope i find a solution here after searching the web for more than one day.
AMD Graphics Card:Radeon RX Vega M GH Graphics
Desktop or Laptop System: Desktop NUC8i7HVB
Operating System: Win10 64bit
Driver version installed: 18.10.26.02-180830a-332836C
Display Devices: LG C8, HDMI 2.0
Resolution:3840 x 2160
Refresh Rate (Hz):59.9394
Motherboard + Bios Revision: NUC8i7HVB + HNKBLi70.86A.0040.2018.0516.1521
CPU: Intel(R i7-8809G CPU @ 3.10GHz, 3096 MHz
RAM: Amount of memory installed; 16GB
thank you in advance
AlHill
Download, run, and ATTACH the results of this utility. Then, an intel support engineer can assist you.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility for Windows*
Doc
attached the requested report.
Hello soundofmaggots,
Thank you for joining this Intel Community.
The latest Radeon™ RX Vega M Graphics Driver for this Intel® NUC is 18.9.1. Are you using a Beta driver? If so, does this issue happen if you use the drivers validated for Intel® NUC Kit NUC8i7HVK?
Intel® HD Graphics Driver: https://downloadcenter.intel.com/download/28205/Intel-HD-Graphics-Driver-for-Windows-10-64-bit-for-the-Intel-NUC-Kit-NUC8i7HNK-NUC8i7HVK?product=126143 Intel® HD Graphics 630
https://downloadcenter.intel.com/download/28194/Radeon-RX-Vega-M-Graphics-Driver-for-Windows-10-64-bit-for-the-Intel-NUC-Kit-NUC8i7HNK-NUC8i7HVK?product=126143 Radeon™ RX Vega M Graphics Driver
Wanner G.
Under Contract to Intel Corporation
Hi Wanner,
i installed the version the intel installation tool suggested.
to be clear the Radeon Software version is: 18.9.1 but the driver packaging Version is: 18.10.26.02-180830a-332836C
But i also had the issue with V 18.6.1
Same with the Intel HD Driver. version i installed: 24.20.100.6286
Thank you for your response.
Please follow these steps to continue troubleshooting this issue:
1. Update BIOS.
BIOS Update [HNKBLi70.86A] Version: https://downloadcenter.intel.com/download/28185/?product=126143 0050 (Latest) Date: 9/27/2018
2. Uninstall both graphics drivers and re-install the latest, Intel first. Please do it manually.
A. Intel® HD Graphics Driver for Windows® 10 64-bit for the Intel® NUC Kit NUC8i7HNK, NUC8i7HVK
Version:https://downloadcenter.intel.com/download/28205/?product=126143 24.20.100.6286 (Latest) Date: 9/27/2018
B. Radeon™ RX Vega M Graphics Driver for Windows® 10 64-bit for the Intel® NUC Kit NUC8i7HNK, NUC8i7HVK
Version: https://downloadcenter.intel.com/download/28194/?product=126143 18.9.1 (Latest) Date: 9/26/2018
C. https://www.intel.com/content/www/us/en/support/articles/000005629/graphics-drivers.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows* 8/8.1
Wanner G.
Were you able to perform the steps recommended above?
If you still need any assistance, we will be glad to help you.
Wanner G.
Hi Wanner,
sorry for my late reply but i had some issues deleting the drivers.
But it seems to work now.
If the issue pops up again i will start a new request.
thnak you for your help so far.
