23780 Discussions
Raid 1 Missing Hard Drive ??
Had a Raid 1 drive fail. Replaced it with new same. Hit CTRL-I during reboot to enter config util and followed the prompts to add the new drive and initiate the auto re-build. Ok. Seems straightforward. Boot to Vista 64 and the rebuild begins. Enter IMSC and it shows the array rebuilding but it also shows that now it contains 3 drives and one of those drives is missing!!! Huh? How did that happen? More importantly, how do I correct it without it crashing the array?
Strangely, after completing the rebuild the array as reported in IMSC appears to be normal and back down to just two drives. Peculiar.
It may seem strange, but what you saw was the expected behavior. You started out with 2 drives in a RAID1 configuration. Let's call them drives A and B. Then Drive B failed. You removed Drive B, and inserted Drive C, and flagged it for a rebuild. When you removed drive B, you effectively had a RAID 1 volume with a missing disk that was rebuilding to a new disk C. The RAID controller will not "forget" about drive B until it has fully rebuilt to drive C. Only once drive C is fully operational will the RAID controller consider drive B to be replaced.
