23762 Discussions
Realtek HD Audio (Stereo Speaker) Driver | Touchpad Problem
Jetflip09
I need help there is no sound output i checked in setting but it only says steam streaming speakers. I also saw another post saying do win + r then dxdiag. I will attach that information on this so it saves time. And there is another problem and thats with my inbuilt touchpad i tried alot of things but cant get it to work, this happened 2 in a half year ago, had to use a mouse. And i don't think the board name is correct my bad...
VARADHARAJAN
Valued Contributor II
Your  laptop has  Realtek audio chip, so install Realtek audio driver which is released on year 2021`
HP Pavilion x360 Convertible 14-dw1xxx (52M15U8) Software and Driver Downloads | HP® Support
If you want to install the latest Realtek audio driver, then download it from the site
Realtek High Definition Audio (UAD) Version 6.0.9709.1 WHQL all (necacom.net)
or
Realtek High Definition Audio (HDA) Version 6.0.9703.1 WHQL All (necacom.net)
Both versions are different and have different features, use the device manager install the driver
Varadharajan K
MUC
Honored Contributor I
Your device is an HP Pavilion x360 Convertible 14-dw1000. You can download the appropriate drivers for this device from the HP website:
Software and Drivers for HP Pavilion x360 Convertible Laptop PC 14-dw1000
Jetflip09
It doesn't have the drive i need. I need 12C HID Device driver i am pretty sure put the hp website only gives the following:
ELAN Fingerprint Sensor Driver
ELAN Precision Touchpad Filter Driver
HP Wireless Button Driver
This is in the category of Driver-Keyboard, Mouse and Input Devices (3). I will be asking the hp forum as well.
VARADHARAJAN
or
Varadharajan K
Mayareddy
Yeah, If there is a problem with the Realtek HD Audio (Stereo Speaker) driver, then the speaker volume may be reduced or the sound may not come out properly. To fix this problem, it is best to update or reinstall the driver. Similarly, if the touchpad does not work or suddenly moves strangely, it may also be due to the driver. Installing the correct and new driver will solve these problems.
langdonjack
@Mayareddy Use the device manager to install the driver; the two versions differ and have different features.
