22965 Discussions
Repeated Prompt to Install .NET to Install Iris Xe Drivers; Installation Not Working, Nonetheless.
dos16
Every time I try to install a new Iris Xe driver, I keep getting a prompt to install .NET 8.0.0. Even though I have, numerous times. I'm sure that this is a bug, yet is there any way to work around it?
dos16
I managed to fix the issue by running the following commands in an Administrator Command Prompt
Dism /Online /Cleanup-Image /CheckHealth
Dism /Online /Cleanup-Image /ScanHealth
Dism /Online /Cleanup-Image /RestoreHealth
 sfc /SCANNOW
Apparently the issue was a corrupted file, which the latter command seemed to fix.
Mike_Intel
Hello dos16,
  1. What is the model of your processor?
  2. What is the brand and model of your system?
  3. Was it working fine before?
  4. Can you share screenshot of the issue?
  5. How did you update the driver?
Michael L.
dos16
1.  12th Gen Intel(R) Core(TM) i5-1235U 1.30 GHz
2.  HP Pavilion x460 2-in-1 Laptop 14-ek0xxx
3. All driver updates were working fine before, yet it seems this specific path requires the .NET framework, incidentally having a bug.
5. I've tried to use: the Intel Driver & Support Assistant and manually install the driver.
Mike_Intel
Hello dos16,
Thank you for the update.
Please try the following steps:
  1. You can download .NET framework here: https://dotnet.microsoft.com/en-us/download/dotnet/7.0
  2. Then install the latest driver. You can download the latest driver here: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Michael L.
dos16
I've downloaded both the 7.0 and 8.0 versions of the .NET Runtime, yet the error still occurs (as seen in the images). I'm quite adamant that this is a bug with the driver/installer itself.
Mike_Intel
Hello dos16,
To be honest, other customers are not having this issue during the installation of the same driver.
It is possible that this is more on the OS side. Have you tried contacting Windows support about this?
Michael L.
Mike_Intel
Hello dos16,
Michael L.
dos16
 sfc /SCANNOW
Mike_Intel
Hello dos16,
Thank you for the update and I am glad that you were able to fic the issue.
And also, thank you for sharing the fix which indeed more on the OS side since there was a corrupted file.
Since you already tagged the case as "solved", I need to close this inquiry.
Michael L.
