23840 Discussions
Saturation Not Showing Up
oweq
Hello there.
I am here to ask a question about why I dont see Hue or Saturation on my intel graphics command center settings. I can show my specs here
and I have a 11th gen Intel i5-11400F 2.6Hz CPU
and I also use a TV as my monitor
PLEASE HELP!
I just want my game to look more colorful 😥
Jean_Intel
Hello oweq,
Have you tried following the steps to adjust color settings? Follow the steps below to change your color settings using the Intel® Graphics Command Center:
  • Open Intel® Graphics Command Center:
  • Click Display in the left navigational menu
  • Select the Color tab.
  • Ensure you are on a custom profile. The Default color profile is locked; to create a new profile, click the large Custom button.
  • Adjust the Brightness, Color, Hue, or Saturation settings as desired.
  • Click Restore to Original Colors to revert any changes.
If you still don't see any Hue or Saturation option, please provide me with a report using the Intel®️ System Support Utility (Intel®️ SSU)
Jean O.
Jean_Intel
Hello oweq,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello @oweq,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
T_I_T_14
Hello there.
I am also facing the same problem.I don't see any hue or saturation option in the color option.
jayz
hello, i got a fix for ya,
STEP 1: make sure you download intel graphics command center BETA!! otherwise it wont work.
STEP 2: open your registry editor, then press ctrl F then a window will pop up, search for this: xvyccfeature
when u see the highlighted text right click on it and press modify, then change the value to 0.
STEP 3: after modifiing it, press F3 on your keyboard, this will search the next one, when it finds it do the same as the step 2 (modify set to zero) and repeat this process until ur F3 button says all registrys probed.
STEP 4: restart your pc, then go to intel graphics command centere beta and you should see the saturation and hue.
MY ORIGINAL YTB TUT: https://www.youtube.com/watch?v=k0nXZ9r_DiE
hope this helps 😄
leave an like and a sub!
