23784 Discussions
“Scale Full Screen” missing from Intel Graphics Command Center
JiRo1
I used Scale Full Screen to send a 4:3 image (keeping the pixels from the app) to my projector (set to 1:1) displaying and filling on a square screen. I may have to take my HP laptop back to the seller.
LeonWaksman
Hi @JiRo1
Download and install the Intel Graphics Control Panel to regain the Scale Full Screen option.
Leon
JiRo1
Hi LeonWaksman, will this Intel Graphics Control Panel work with Windows 11 OS and Intel Ultra 7 processor?
JiRo1
JiRo1
I have a solution, though not ideal.
I found that Intel Graphics Command Center/Scale has two options (Maintain Display Scaling & Custom) from the drop up window when my 2nd display is connected (projector display) with 1600x1200 resolution as set in the Windows/Settings/Display/Scale&Layout - Display Resolution.  (I need the 4:3 aspect ratio to transfer my app image to the projector.)  But when I lower the resolution to 800x600 (4:3) or to 1024x768 (also 4:3), the Graphics Command Center/Scale now has 5 options: 1) Centered, 2) Stretched, 3) Maintain Aspect Ratio, 4) Maintain Display Scaling, and 5) Custom.  (Sometimes when these resolution are selected, "Maintain Display Scaling" option is missing.  Don't understand the rhyme of this.)
When I select "Stretched", the projected image goes from 4:3 to 1:1 (projector screen fill ratio user setting) and fills up my square screen.  Voila!
So this solution isn't ideal since I can't use the max 4:3 resolution of 1600x1200.  So my Intel Case will remain open.
Hope this helps others,
JiRo1
DeancR_Intel
Hi JiRo1,
Thank you for posting in the Community!
I understand that you have a laptop. Since this is an OEM (Brand) original equipment manufacturer device, please take into consideration that our support may be limited since we are not familiar with the technology, settings, customizations, custom drivers, and features that the OEM has designed and installed your system.
You may look up into these links for your reference:
Scale Options Are No Longer Available After Updating the Intel®...
Error: "Custom Resolution is Not Supported on Internal...
I suggest trying the following from your OEM:
Troubleshooting HP Laptop Screen Display Issues: A Comprehensive Guide
Dean R.
DeancR_Intel
Hi JiRo1,
Dean R.
DeancR_Intel
Hi JiRo1,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
