23851 Discussions
Scalling Problems Override Applications Settings doesn't stay selected.
DAlex3
Scalling Problems
I right click on the monitor , I go to graphics properties i select display and at the bottom is Scalling , I select Scale Full Screen and I press Override Application settings but It doesn't stay like that , after I press apply the Override Application settings unselect by itself.
I want to do this for cs:go.
What can I do?
I think that happen after a update at Windows , because 1 mount ago works perfectly
Denis3K11, Thank you very much for joining the Intel® Graphics communities.
In order to better assist you:
What is the model of motherboard, processor or laptop?
Which Windows version are you using?
Which is the version of the graphics driver currently installed?
You mentioned the system was working properly a month ago, do you remember the graphics driver version that was installed back then?
Any further questions, please let me know.
Alberto
Denis3K11, I just wanted to check if you saw the information we requested previously and if you need further assistance on this matter?
Alberto
