23775 Discussions
Screen flashing at startup
ashaw1
Im getting this flashing when PC starts up and goes to desktop, with nothing else switched apart from the monitor and Pc on its its ok but when my TV is on and i start the Pc up that's when i get the flashing, i think its something to do with the graphic card or settings within.
I tried a different socket on the TV and it started flashing again so its definitely something to do with the HDMI, there's nothing wrong with the cable, as it works perfectly.
Im using a Asus Z97-A mobo with Intel 4600 on board graphics and is new, and all updates and drivers are up to date.
I have done a video of it which shows the monitor and hope someone can tell me what's going on and how to rectify it, or if there is nothing to worry about, can be found here,
http://s1177.photobucket.com/user/andsaw/library/computer Computer Photos by andsaw | Photobucket
Allan_J_Intel1
Have you tried loading the latest video drivers? what is the driver version number?
https://downloadcenter.intel.com/ https://downloadcenter.intel.com/
Which version of Windows do you have?
Do you know if this problem occur with Intel drivers and Original Equipment Manufacturer (OEM) drivers?
Allan.
ashaw1
Hi Allan,
I have the latest driver 10.18.10.4156, im running W7, im not sure as to Intel or not, i loaded the Asus update drivers from their site then put Intels on but i think it did it on both, i am going to borrow another Tv and see if the same happens but that wont be till Thursday.
Allan_J_Intel1
Thanks for the update. Let me know if you still have same problem using different TV.
Allan.
ashaw1
I got another TV yesterday and tried all situations and the borrowed TV did not show the same behavior as my TV, so i can only imagine that its something to do with the HDMI connection on my TV, but have no idea as to what i can do, also tried 2 different cables so its not cable related.
