22988 Discussions
Screen flickering/static and graphics driver failing/recovering help
kcher2
For the past week or more I have been having problems with my LCD screen for my laptop flickering/changing random colors/lines appearing/flickering, etc. Originally, I thought my battery was shot and was causing power loss to the lcd. I guess that was not the case since a battery replacement did not help.
Now for the last couple days ive been getting errors saying my display drivers have stopped responding and have recovered.
I honestly dont know that much when it comes to Intel drivers/products/etc. Here are my stats: (Also, this might not be enough data to work with, just let me know if anything else is needed)
Intel(R) HD Graphics 3000 with installed driver version 9.17.10.4229
i7-2670QM @ 2.20 GHZ x8 with installed driver version 6.1.7600.16385
Now, I've tried the driver update software. It tells me to download:
Intel Chipset Device Software (INF Update Utility-exe only)-10.0.27
Intel Proset/Wireless software and drivers (Windows 7/8/8.1, 64 bit) for legacy adapters (6200/6230) -15.17.0.1
When I try to download the first one, it says it was successful in the window that comes up initially, but says failed in the update utility client.
The second one when I try to download, it says "Installation Blocked: This version cannot update from the older product. Please uninstall the older product manually"
So, my initial thought to just update my drivers isn't helping. I would love to get some help with this as my computer is almost unusable sometimes.
Amy_C_Intel
Hello kylec123,.
I would recommend to install the latest version of the Graphics Driver from our site, please visit https://downloadcenter.intel.com/product/81500 Downloads for Intel® HD Graphics 3000 for 2nd Generation Intel® Core™ Processors, I would also recommend performing a manual installation of the driver. Here are the instructions for the Manual Installation http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*.
Here are some helpful links that might help you to fix this issue;
http://www.drivethelife.com/windows-drivers/how-to-fix-display-driver-stopped-responding-and-has-recovered-on-windows-10-8-7-xp-vista.html How to Fix the "Display Driver Stopped Responding and Has Recovered" Error | OSToto.
https://support.microsoft.com/en-us/kb/2665946 https://support.microsoft.com/en-us/kb/2665946.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
For further information you can check the following link http://www.intel.com/support/graphics/sb/cs-009483.htm Graphics Drivers — Errors Reported By Microsoft*.
Let me know your findings.
Amy.
