22988 Discussions
Second monitor resolution maximum
LM7
I have a Microsoft Surface Pro 4 connected to a docking station and running Intel Iris Graphics 540.  I bought a new 32" Samsung monitor and cannot get the resolution beyond 1920 x 1080. The supported resolution is significantly higher than this.:
https://support.microsoft.com/en-us/surface/troubleshoot-connecting-surface-to-an-external-display-bc8f5121-a4cb-cf0b-5770-2df7a66a3b28#bkmk_checkdisplayportsetting_w10
I have not had this problem with previous large monitors.
I have tried several troubleshooting steps:
  • Installed the most recent driver.
  • Connected the HDMI cable adapter to the port in the back of the docking station
  • Connected display wirelessly
Also, when I connect the monitor to a Thinkpad, the resolutions available are significantly higher.
Please advise.
Thank you.
Jean_Intel
Hello LM7,
Thank you for posting on the Intel️® communities. We understand that you are having issues setting the native monitor resolution.
To have a better understanding of your issue, please provide me with the following:
  • When did the issue start?
  • Disconnect any video docking station and use a straight connection instead. Some 3rd party components may prevent or alter the capability of the Intel Graphics to read the display's Extended Display Identification Data (EDID) data.
  • Have you tried using a different video cable or video output? Some cables might yield the worst data transfer capabilities and limit the display's capabilities.
  • We also want to have more information about your system. Create the system reports using the following tools:
    • Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
  •  Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello LM7,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello LM7,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
