22946 Discussions
Shader cache files showing device id and extension saying 0_APPNAME=
Xillvion
New Contributor II
This appeared in driver versions 32.0.101.6297 and 32.0.101.6299:
Is this a bug? Though it will be very nice for it to show the name of the application that's using the amount of shader cache.
Also some shader cache files is outside of the Intel folder, where the LocalLow folder is, not sure if it's intentional or not.
I'm on a Acer Aspire A515-56 laptop, i5-1135G7 with Intel Iris Xe Graphics.
Earl_Intel
Hi Xillvion,
Checking on your inquiry, I have few questions for me to better understand the issue.
Earl E.
Xillvion
New Contributor II
  1. The Intel one
  2. Just only one NVME drive
  3. Not sure what you mean by the graphics driver folder, same place as all other drivers? But here's the two screenshots:
The empty space after the Users folder is the account name folder. As you can see in the first screenshot, some of the shader cache files are outside of where the Intel folder is. I'm on a older driver due to an issue with a game I already reported, but the DeviceId shader cache files appears on those two graphics driver versions I pointed out.
Earl_Intel
Hi Xillvion,
Thank you for sharing this information, I will further check on this and will provide you an update as soon as possible.
Earl E.
Earl_Intel
Hi Xillvion,
Thank you for patiently waiting.
The shader cache folder is a directory where temporary files generated by your graphics card are stored. These files include precompiled shaders, which help improve performance by reducing the need to recompile shaders every time a game or application is run.
The LocalLow folder is a subdirectory within the AppData folder on Windows systems. It is used to store data for applications that run with lower security settings, often referred to as "low integrity" applications. This folder is typically used by web browsers running in protected mode and other applications that require restricted access.
We replicated the issue using our Intel NUC LAPBC510 system with an i5-1135G7 processor. We checked the folders and found that it is normal for the files to be stored in those locations, even on systems without an Intel graphics card. Therefore, this behavior is expected as explained above.
Let me know if you have other concerns.
Earl E.
Xillvion
New Contributor II
Okay, what about those shader cache files in the first screenshot that's incorrectly saying it's a D3D12 aka DirectX 12 file?
Earl_Intel
Hi Xillvion,
Thank you for your response, upon further checking.
"DirectX 12 (DX12) is the API that includes Direct3D 12, Direct3D 12 provides an API and platform that allows apps to take advantage of the graphics and computing capabilities of PCs equipped with one or more Direct3D 12-compatible GPUs."
Here us the source link: Direct3D 12 programming guide - Win32 apps | Microsoft Learn
Best regards.
Earl E.
Xillvion
New Contributor II
I know about that, i'm actually talking about the fact that the shader cache for Fortnite says it's a D3D12 file but I'm using DirectX 11 since the latter requires the ultimate version of DirectX 12. And Arc Control as well, unless it uses some Direct3D stuff.
Even so, it's only some of the shader cache files that showing the DeviceId and 0_APPNAME= and not the rest like the one in the 3rd screenshot. I do have a concern about stability, performance and potential security risks for those files.
Earl_Intel
Hi Xillvion,
Thank you for your response, noted on this.
Give me enough time to investigate on your concern, I will provide an update on this thread as soon as possible.
Earl E.
Earl_Intel
Hi Xillvion,
We tried to replicate the issue on our end. Upon investigation, it would be best to consult the game developer. The files you are asking is related to 3rd party game developer, kindly refer to the game developers for assistance in order to provide you with the best solution for your inquiry.
Earl E.
Xillvion
New Contributor II
Nope, that isn't on them. Whatever it is, delete this post.
