22974 Discussions
Skyrim special edition texture problem on Intel hd 530
hhau
Skyrim special edition in Intel hd 530 have many texture flicker especially around character.The beta driver(battlefield 1,Fifa driver) is not fix this problem
Hello hjymnol:
In order to better assist you, we just need to verify the following information:
What is the model of the motherboard?
What is the model of the processor?
If this is a laptop, what is the model of the laptop?
Which Windows version are you using?
Alberto
hhau
os: Windows 10
motherboard: H110M-D
processor: Intel core i5 6400
this is desktop computer
hhau
I see some gameplay on intel hd 4000,4400 and it didn't have this problem only Intel hd 530 have this so I think this is driver problem ?
Hello hjymnol:
Thank you very much for that information.
Yes, this could be related to a diver problem.
Since the processor is working with Intel® HD Graphics 530 controller, please try to un-install the correct graphics driver manually and the install the ones below manually as well:
Un-install driver manually:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html
Install driver manually:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
We can try driver 4501 first:
https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
If that does not work, we can try beta driver 4539:
https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
If the problem remains after that, we can try the graphics driver provided by ASUS, look for VGA:
https://www.asus.com/Motherboards/H110M-D/HelpDesk_Download/ https://www.asus.com/Motherboards/H110M-D/HelpDesk_Download/
Also a BIOS update might be helpful on the board, the latest version is 2002, you can find that on the link above.
Also, on the link below you will see the recommended settings for Skyrim, you can always try that:
https://gameplay.intel.com/GamesSettings/8630/88185/intel-core-i5-6400-processor-br-6m-cache-up-to-3-30-ghz- https://gameplay.intel.com/GamesSettings/8630/88185/intel-core-i5-6400-processor-br-6m-cache-up-to-3-30-ghz-
Alberto
Hi, I have the exact same problem as hjymnol. My PC is a Skull canyon NUC6i7KYK which uses the Iris Pro 580 with the latest drivers 15.40.xx.4539. Please fix this with a new driver.
DDani22
Hi unfortunately have a Nuc and have the same, ist sad since the performance in the game is quite good I go even on ultra settings but the flickering kills it. Hope intel responds fast.
hhau
Thanks for helping me but the problem still occur. I guess i need to wait for you guys to release a new driver
Hello:
To all the peers viewing this thread, I just wanted to let you all know that we will be more than glad to assist you in trying to fix the problem the PC might have.
For us to be able to start an investigation on this subject, please submit your inquiry on a new thread, the reason for that is that every scenario is different, even if the same product is being used, so, for us further assist you and also in order for us to help you with the specific problem the stick might have., please submit a new thread.
Let me apologize for any inconvenience.
To hjymnol:
The next thing that we can try is to try to replicate the issue, for that we just need to verify a few details, please fill as much information as you can:
CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issue Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>Always (100%):
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):</td>Hardware (HW)Brand and Model of the system. Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too? Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in) How much memory [RAM] in the system (see note2 below). Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc Hardware Stepping (see note1 below). Software (SW)<td style="width:299px;border-top:none;border-left:none;border-bottom:solid w...
hhau
CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issueTexture flickering around characterPlease place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>Always (100%):X
Often (51-99%):
Sporadic (20-50%):
ASUSTeK COMPUTER INC.
ie Does it have AMD or NV graphics too?NoMake and model of any Displays that are used to see the issue (see note2 below).
EFP = External Flat Panel (Monitor you plug in)Samsung LEDHow much memory [RAM] in the system (see note2 below).8gb ram DDR4Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etcHardware Stepping (see note1 below).Software (SW)Operating System version (see note2 below).</span...
Hello hjymnol:
Thank you very much for providing that information, it will be very useful for us in order to better assist you.
Now, we will start an investigation on this matter in order to try to find a possible fix for it, as soon as I get any details I will post all the information on this thread.
Alberto
hhau
I have tried newest driver(4542) that you guys have just released and the problem still occur.Hope you guys can fix this fast.Thanks for your hard work to make many game can play on onboard graphic
DXion1
same problem on Intel HD 520 (Acer V3-372).
SLong5
Hey Intel first of all you guys are awesome to make so many games run on your CPU's onboard graphics some even on Low to Medium settings like starcraft 2 on a intel i3 6100U is amazing so thank you for the hard work you guys do. My main PC is still running its old Intel i7 3820 and its still running like the beast it is.
I also have the Intel NUC6i3SYK and am experienceing this issue. I see what looks like white spots like snow textures or something on everything in the game Skyrim Special Edition I did notice that Bethesda the game developers have an update for the game version 1.1.51 so I will try that out and report back here.
When i load into the game it also takes a wee bit of time for the menu to appear first I get a black screen with the in game music and if I wait around a wee while maybe two to three minutes the game pops up and i can then start it.
Edit:
Nope after applying the latest update the game is still the same.
I am running skyrim special edition on the lowest settings possible apart from my resolution.
With the update it's worse the game textures flicker like mad as well as still having the random textures there.
Edit 2:
Thought I should share the correct specifications.
I am running an Intel NUC6i3SYK on Windows 10 64bit Anniversary update
This NUC Features
Intel HD Graphics 520 - I'm running the latest driver I could find for this.
Full Sized HDMI for 4K graphics - Surely this is for desktop stuff right?
Support for one M.2 I think mine is a AData or something 512 gig I think sata 6 gb/s
I think I have 4 gigabyte of DDR 4 SODIMM Can't remember the speed in MHZ
Intel Dual Band wifi 802.11 and bluetooth 4.1
4 USB 3.0 ports
Intel Gigabit lan
SD card slot
I even tried an ENB and that didn't help infact it made it worse.
I think I may revert to the original main version of the game and then try a mod called SMIM which redoes the textures, This mod has worked on Xbox one and PS4 versions of the game without any decrement to performance and maybe it will fix this weird texture which looks like the snow being incorrectly textured or lighting.
ATran10
Having the same problem. I've tried the mentioned above fixes.
Running Skyrim Special Edition on a:
Dell XPS 13 9350
Intel i5 6200U
8GB Ram
HD 520
256GB SSD
WIN 10
RonaldM_Intel
Hello fellow gamers,
I would like to let you know that we reproduced this issue already, and our development team is looking for a fix [bug ID# 1804665068].
As soon as we have an update, I'll let you know here.
In the mean time, can you try changing the "General Settings" to "Performance" and let me know if it makes any difference?. The option is located in the 3D settings in the Graphics Control Panel. Please report back if that makes any difference and I'll update the existing bug report with your feedback.
Many thanks!
DDani22
Hi Ron,
its not connect to the performance settings, tested it with and without "performance" as well any other settings dont impact it, you should know the game is not able to detect the GPU, in mine case the 580 pro
seems to really be a feature of the driver to me
Good luck, looking forward to the fix
Daniel
ATran10
Ron,
Thanks for the response and I appreciate the effort your dev teams have taken to correct the issue.
To follow up on the performance setting - changing this has no affect on the flickering issue I've been receiving.
Kind regards!
hhau
Still no fix yet.Did anyone found a temporary fix yet?
RonaldM_Intel
Hello everyone,
We just published a new Beta driver that should address most graphics corruption in Fallout 4* and The Elder Scrolls V: Skyrim Special Edition*.
Please review all the information on this Beta before doing the installation:
We appreciate all the feedback you can provide us on this Beta.
Kindest Regards,
DDani22
Hi Ron,
happy to confirm, preliminary test show issue resolved, and subjectively it seems even a slight performance improve. I have not tested it in depth no time for that but checked some locations, trees, armor all fine, thanks very good job.
