22888 Discussions
Solidworks 2015 hangs on file loading, only when well focused in external monitor
dneau1
Solidworks 2015 X64 SP3
Hangs on file loading, only when well focused in external monitor, every time
Works fine with built in monitor
MSI GE72
i7-5700HQ
Windows 10 x64
EFP E2442TC (LG) monitor
12G ram
extended desktop
15.4404 drivers
Bryce__Intel
Hi danneault
Please read this sticky and fill out the form completely. We'll begin investigation once we've received it. Currently we've tried to replicate what you say here but are unable to experience this. Additional information from you hopefully will help. VERY important, please provide the picture or video of the failure. Appreciate it!
dneau1
Latest release direct X (it's windows 10, not like I have control over it)
To reproduce, open solidworks in an external monitor, start a new part, few minutes later the whole system hangs
Can't get a picture if the system is hung
Solidworks 2016... same thing
No problem if you use the internal monitor
Bryce__Intel
That's the problem, it won't repro for us. Which suggests it may be something with your specific configuration. We'll need that to proceed with investigation. I forgot to include the sticky link.
EstebanA_C_Intel
Hello, danneault:
Thank you for contacting the Intel Communities.
We look forward to the information to be provided about this scenario.
Esteban C
dneau1
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
See above
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
yes
Hardware (HW)
Brand and Model of the system.
MSI GE72
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
YES
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
How much memory [RAM] in the system (see note2 below).
<td style="padding: 0 5.4pt; border-right-width: 1pt; border-botto...
Bryce__Intel
Hi danneault
Could you please take a video of the failure with a webcam, phone or other device and attach it to a response?
Unfortunately the Developer still cannot reproduce this issue. A video or screenshot that shows window positions during or even before hang occurs might be helpful. For example I don't know if SolidWorks window on extended desktop is maximized or not, etc. Please use Advanced editor>Attach to attach the video file to the reply here. Thanks.
Much appreciated.
Bryce__Intel
If the issue is resolved for you or you're unable to provide the failure video I'll need to close this out. Let me know.
